rear window wiring
Old May 1, 2001 | 11:59 AM
froggy323's Avatar
froggy323
rear window wiring
I recently purchased a 1989 Bronco, but the wiring for the motor for the back window was cut out and removed by the previous owner. I have the connection for the key operation of the rear window that is in the gate, but I have no clue which wires go to that and which go directly to the motor itself. I have tested the motor, and it works fine; I have also tested all of the wires coming back from the main switch in the dash, and they appear to working properly. There are six leads coming out of the front dash switch, but I cannot determine where they go.
I even purchased a Chilton's Bronco Repair Manual, but it did not have any info on the wiring of the rear window. Please let me know if you know how to fix this or if you know of where I could get a wiring diagram for the rear window.
Old May 5, 2001 | 01:03 AM
desperado_18_2000's Avatar
desperado_18_2000
rear window wiring
gabes
May 8, 2015 09:12 AM
rider736
1978 - 1996 Big Bronco
Oct 28, 2009 08:09 PM
uscrpick
Mar 11, 2007 09:08 PM
jason86
Jun 22, 2005 01:53 PM
broncosavage
May 27, 2005 06:52 AM
