Offroad & 4x4
fender grinding...
Old Mar 10, 2003 | 10:35 PM
MEPR's Avatar
MEPR
Thumbs up fender grinding...
Alright im NOT going to lift my 150 im going to put 38s on it. My question is how much of the fenders will i have to cu away.
Old Mar 10, 2003 | 11:34 PM
steve83's Avatar
steve83
fender grinding...
I'd guess about 4" on top and at least that much front & back.
Old Mar 11, 2003 | 06:50 AM
72f100's Avatar
72f100
fender grinding...
ALOT
I would cut up to the bottom of the body line. Use your factory openings as a guide so you can get the shape right and it'll look pretty good. Use a marker to draw them first, don't try to free hand them. Also, try not to trim too much as it will look rediculious if you should ever decide to put on smaller tires. If you do it right it will look good w/ anything from a 35-38" tire on it. If you cut too much your stuck w/ 38's (which isn't all that bad if you always have the money to buy 38's)
Old Mar 11, 2003 | 04:57 PM
tellico racing's Avatar
tellico racing
fender grinding...
Check out my gallery, I have 40" tires and no lift.
Old Mar 11, 2003 | 07:38 PM
MEPR's Avatar
MEPR
fender grinding...
well the cash sint the huge issue as it will see next to nothing for road miles, it will be a mud racer. Thanks for the imput guys when im redy for the cutting to begin im basicly going to add about 5-8" to the stock wheel openings and try to keep the same lines/look as the stock ones. Should be fun!
Catanna69
19
Aug 10, 2016 07:22 AM
small town guy
Feb 27, 2016 08:40 PM
NewEnglander
1978 - 1996 Big Bronco
15
Mar 19, 2015 09:55 AM
arrowheadfred
Dec 14, 2010 05:59 PM
78_f800crewcab4x4
Large Truck
Jan 12, 2010 04:58 PM
