cruise control problems
Old Feb 5, 2011 | 12:00 AM
firebug's Avatar
firebug
Does anyone have a diagram that shows all the components of the cruise control system? My cruise just works when ever it wants (with me pushing the button) sometimes it works great for about 20 miles give or take then just shuts its self off, sometimes it will reingage, but usually not. Some days it wont work on multiple attempts then all of the sudden it desides to work. It has me totally confused. Just to note: all three brake lights do work, the recall on the switch on brake master cylinder has been done. Any suggestions would be appreciated, I rely on my cruise alot, 95miles one way to work. Thanks, sorry for long post.
Old Feb 5, 2011 | 12:17 AM
kawa's Avatar
kawa
Talking
You could have a bad switch but....check your third brake light. Make sure that the contacts are clean and that it isn't loosing continuity as you drive as that will cancel the OD.
Rog
Old Feb 5, 2011 | 12:31 AM
firebug's Avatar
firebug
I will check the third brake light contacts, what switch might be bad.
Old Feb 5, 2011 | 12:47 AM
kawa's Avatar
kawa
The switches that come to mind are the ON/OFF & SET. Bear in mind I'm just guessing. Perhaps someone that has had this type of problem will chime in.
Rog
Old Feb 5, 2011 | 05:45 AM
Copedawg's Avatar
Copedawg
Not a good copy. I have a better copy I can e-mail you but it is at work, unfortunatly
Old Feb 5, 2011 | 06:09 AM
427 fordman's Avatar
427 fordman
unplug the elec. connection at the brake master cylinder and look for moisture..
Old Feb 5, 2011 | 07:35 AM
DIYMechanic's Avatar
DIYMechanic
I had an issue like that on an '87 Mustang GT I had. It ended up being a poor ground through the steering column duet to a couple loose bolts in the steering column. If you have any up/down slack or wiggle in the column, I would look into this.
Old Feb 5, 2011 | 08:04 AM
RRranch's Avatar
RRranch
any brake light bulb that is out can shut off the cruise when you use the turn signal. Messed up trailer wiring can too and also trailer brake lights if you didn't wire them right. Not just the third brake light.
Old Feb 5, 2011 | 09:56 AM
Cratos's Avatar
Cratos
there is a recall for the cruse switch on the master cyl.could be your culpret
Old Feb 7, 2011 | 02:35 PM
Copedawg's Avatar
Copedawg
If you pm me you e-mail, I will send you the diagram (tomorrow). It is quiting time now YABBA DABBA DOO!!!!
Old Feb 8, 2011 | 01:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
He said that the recall has been done.
njstevens
Oct 1, 2021 09:41 PM
Pipeliner_86
Dec 3, 2015 07:01 AM
Dgmisho12
Modular V8 (4.6L, 5.4L)
May 28, 2015 10:11 AM
Todd Fuller
May 22, 2015 09:59 AM
imacitybilly
Sep 3, 2014 03:27 PM
