need help
Old Mar 20, 2011 | 09:55 PM
OrFordGuy's Avatar
OrFordGuy
i'm with the guys before i get you into a situation where you somethin or have to send it to a shop for repairs on your "repairs", how much mechanic knowledge do you have??????? i read you replaced a head gasket so if my thought is right you could handle a simple swap as long as you can folloe directions and i mean to the letter...
Old Mar 20, 2011 | 11:06 PM
bamaf150's Avatar
bamaf150
A 300 inline 6 cylinder may be you best bet, economical, durable, torquey.
Old Mar 21, 2011 | 03:54 PM
Xpebrian1's Avatar
Xpebrian1
thanks for the info and ideas.
i have done some work on an engine befor work as follows.
i rebuilt my manuale transmitchion and removed and installed the motor in my volkswagen bus.
just wandering what optchions where out there for fords i know that installing a diesel motor or one with efi is tricky work just new to the ford trucks .
sorry if i botherd any body buy the questions i asked just new to thease grate old ford trucks .
thanks brian
Old Mar 21, 2011 | 04:37 PM
jjski78's Avatar
jjski78
thanks brian
Just an FYI: you are now working on a far more complicated animal.
Old Mar 21, 2011 | 04:45 PM
Death85e's Avatar
Death85e
Brian i am sure that you did not bother anyone with the questions that you have asked since we all feel that the only dumb question is the one not asked. However, on that note, the one thing you have to keep in mind here is that even though most of us are rednecks/hicks/ or just plain nuts about these trucks we all appreciate the ability to put a sentence into some sort of legible structure and we all appreciate some sort of decent spelling.
No i am not coming down on you just giving a bit of an observation ( a dictionary can be your very best friend ) as most of us here already complain about the education system and schools and teachers passing students along without the proper ability to cover the three R's: Reading, Writing and Arithmetic. Many of us are old school where we would get absolutely flamed in school and in life by our peers and our elders if we could not spell, do math and read.
As for the ease of doing an engine removal and reinstallation or even a full transplant of another type of engine, anyone who can read a book and follow directions in a very orderly manner can do this job especially if you have people like we have here at FTE to help in answering your questions and help in guiding you along with the proper instruction in an orderly fashion. So long as you have the patience to follow a plan and advice given, you can do anything on these trucks and will eventually get to the point of being able to offer up your own advice and instruction based on learned knowledge of doing it yourself.
Old Apr 1, 2011 | 02:54 PM
Xpebrian1's Avatar
Xpebrian1
390 motor info
Have 76 ford f150 4 wheel drive with 390 motor.
motor has electronic ignitchion.
The 390 motor i have located dose not have electronic ignitchion.
will this motor still worck in my truck or will i need to find one with electronic ignatchion
thanks for any help info Brian
Old Apr 1, 2011 | 03:04 PM
Death85e's Avatar
Death85e
That engine will work in your truck and you can probably use your electronic ignition in it as well . All you will need to do is swap your ignition components over to it.
Old Apr 8, 2011 | 12:18 AM
OrFordGuy's Avatar
OrFordGuy
swap your current distributer into your new motor and your off...
Old Jun 24, 2012 | 08:50 PM
Xpebrian1's Avatar
Xpebrian1
need help
[QUOTE=Xpebrian1;9924870]have 1976 ford fi50 need help info on removing motor frome truck so i can rebuild it[/QUOTE
finly found running 390 motor got old motor removed started knstalling new one.
proablum i am having is moter is almost in motor mount bolts are on the eadge of the holes in the mounts in the truck no matter what i dew i cant get motor to slide in to place .any ideas on what could be causing my proablum i have tried evorything i can thinck of what should i look for or do to get motor in truck
thanks alot for any sugestions ideas
grizzly11
Jun 18, 2010 03:02 PM
mjs
Feb 27, 2003 06:49 PM
unreng
Electrical Systems/Wiring
Dec 16, 2002 05:22 PM
cek181
Nov 26, 2002 04:24 PM
CobraXP
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 15, 2002 01:31 PM
