Sponsored by: Real Truck
need help finding the OBD II connector
Old Mar 23, 2001 | 06:33 AM
mjs's Avatar
mjs
Old Apr 11, 2001 | 07:32 PM
spridget's Avatar
spridget
The check engine light comes on intermittently on my 1997 F350 Dually. I got an Actron scanner to see why, but I can't find the connector anywhere under the dash. Can anyone give me some advice on locating it? Is it possible that I'm looking for the wrong connector because some type of adapter is needed? Thanks for any help.
Old Apr 11, 2001 | 10:23 PM
nitro94's Avatar
nitro94
If your scanner will axcess OBD11 systems then the connection on it will look like the mirror image of the one on your truck. No extra connecions are necessary as all OBD11 terminals have to be the same no matter what year or what brand of car domestic or foreign. They also have to be in plain sight and are usually on the drivers side left of the centerline right at the edge of the lower dash panel.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Apr 18, 2001 | 08:50 PM
spridget's Avatar
spridget
Well, it turns out that the '97 F350 dually doesn't have OBD II! I guess there must be some special rules for heavy duty vehicles. It does have an EEC IV, and I found a site that tells how to use the check engine light to find the problem. The truck is all better now. Thanks.
Old Apr 22, 2001 | 08:14 PM
sleddingbetty's Avatar
sleddingbetty
[font size="1" color="#FF0000"]LAST EDITED ON 22-Apr-01 AT 09:17 PM (EST)[/font][p]
Old Apr 25, 2001 | 07:53 AM
ms_scsi's Avatar
ms_scsi
Yes the 97s did not use ODB II. The 99 F350 was the first year that it was installed. It was on the 98 F150, so you missed it by 1 year.
Scott.
Old Feb 26, 2003 | 07:42 PM
ranger6's Avatar
ranger6
The connector is in the engine compartment, l/h side. HD's for that year use EEC IV. If you go to Autoxray's website it has a connector locator for all yaers and types of vehicles.
Old Feb 27, 2003 | 06:49 PM
4x4x4x4's Avatar
4x4x4x4
The conectors you need to use are located at the rearmost left fender apron.They are plugged into a dust cover.You need to jump across the Diagnostic Link Conector (DLC) and the Self-Test Input (STI) conector.The stored codes will flash on the check engine light,but you'll need a book for the code listings.
