Boost??
Old Feb 9, 2011 | 02:48 PM
Ducci's Avatar
Ducci
So unplugging it will get read of the feeling like the brakes are on when it is cold or not up to running temperature?
Old Feb 10, 2011 | 07:54 AM
JT250's Avatar
JT250
Yes it will
Old Feb 10, 2011 | 09:51 AM
Ducci's Avatar
Ducci
JT250, thanks for the reply. I will have some time tonight after work and before it gets dark so I will unplug it and see how she dose in the morning tomorrow. Do you take the wires back to where they mount similar when you remove the AIH or just wrap the plug and tie it up somewhere?
Old Feb 10, 2011 | 02:24 PM
Pocket's Avatar
Pocket
On mine, it's simply unplugged and dangling. Been like that for a couple of years now.
Old Feb 10, 2011 | 03:24 PM
Ducci's Avatar
Ducci
By having the EBPV disconnected will this negatively effect the engine to warm up for the 3-5 minutes? I know the EBPV is there to help with warm up (may tack longer) but I am more concerned with any mechanical negative effects on the motor?
Old Feb 10, 2011 | 06:08 PM
Pocket's Avatar
Pocket
Driving it is the best way to warm it up. The only time my truck idles is if I'm scraping snow off of it.
But to answer your question, no a short idle time like that won't have any real effect. Consider that for the first 2 minutes your truck is idling (depending on temps), the EBPV isn't even engaged. High idle and the EBPV do not engage until the glow plugs shut off.
Old Feb 10, 2011 | 10:01 PM
Ducci's Avatar
Ducci
Well I disconnected the EPBV wire from the lower pedestal after work. I then took the truck out later and it was like driver a different vehicle. The truck has way better throttle response. However after I turned the motor off for about an hour and then came back out to start it and drive the truck back home the SES light came on? I have had the AIH delete done as well but this is now the fist time the SES light has come on sence owning the truck?
Any thoughts?
Old Feb 11, 2011 | 09:30 AM
JT250's Avatar
JT250
No dont know why you got the light. I didnt get it and the EBPV shouldnt cause that. I have the AIH and the EBPV and dont get the light. Has it gone off now that you shut the truck off and restarted?
Old Feb 11, 2011 | 10:23 AM
Ducci's Avatar
Ducci
No the light was still on this morning. The truck seem a little louder from one of the injectors but it was could out so I will have to see how it sounds at full warm up. I have some running around to do later today so will see how things do warm. But I did not think the SES light would come on with these disconnected?
Could it be the EBP sensor? I have not checked the tube or the sensor sense I bought the truck these are on my list of things to do?
Old Feb 11, 2011 | 10:45 AM
JT250's Avatar
JT250
It is probably just a coink i dink that it came on when you disconnected it. It could be one of many things. The only way to know is to get someone to check it for you. The truck will be louder when cold though. You will probably notice it more now that it is not restricted by the EBPV.
Old Feb 11, 2011 | 10:52 AM
Rose Clifford's Avatar
Rose Clifford
anyone have a pic of the ebpv plug to pull in order to disable it?
Old Feb 11, 2011 | 10:53 AM
Ducci's Avatar
Ducci
Well I have been thinking about getting a Scangauage. I will probably unplug the battery and then plug the EBPV in and see if the SES goes out and if it will come back; an easily free check for the moment.
Old Feb 11, 2011 | 10:57 AM
  #28
Ducci's Avatar
Ducci
https://www.ford-trucks.com/forums/8...-delete-2.html
Look on the second page a couple posts down from the top.
JHG88F350
Jan 17, 2015 10:58 PM
kupaa
Mar 15, 2009 01:18 PM
sean23johnson
44
Jan 9, 2007 10:54 PM
Turf Truck
Feb 6, 2004 11:15 AM
