Boost??
Old Feb 3, 2011 | 03:42 PM
Ducci's Avatar
Ducci
Boost??
Was wondering if it is normal for the truck to make more boost when the truck is at operating temperature? My drive in the morning is pretty short and even with a warm up prior to driving the truck rarely gets in the normal range on the gauge. This after non while driving around town and with the truck nice and warm the boost was consistently higher throughout all shifts and driving speeds. Recognize this is a mostly stock truck and seams to mostly run under 5psi around town and sometimes higher on taking off from a stop. Is this normal, I just installed the gauges this past weekend.
Thanks
Old Feb 3, 2011 | 04:32 PM
Pocket's Avatar
Pocket
Yep, normal.
Fueling, timing, and ICP are adjusted by the PCM when the engine is cold. It's just part of the stock Ford programming.
In addition, if your truck is mostly stock, then your EBPV (exhaust back pressure valve) is probably functioning and working as it should to restrict the exhaust flow... which will cause less power and lower boost pressures, but warm the engine faster.
Old Feb 3, 2011 | 04:45 PM
Ducci's Avatar
Ducci
Thanks for the quick answer. This is what I had thought but I am still very new to PSD; trying to learn all I can. I would like to remove all the EBPV stuff some day but have no real reason to get into the turbo at the moment.
Old Feb 3, 2011 | 05:03 PM
Rose Clifford's Avatar
Rose Clifford
might not want to do that if you live in a region that sees freezing temps
Old Feb 3, 2011 | 05:11 PM
Ducci's Avatar
Ducci
I live in California so I am not too worried about it. The valley dose get cold but nothing like what the rest of the country is dealing with now.
Old Feb 3, 2011 | 05:13 PM
Rose Clifford
delete the thing then good luck to ya brother
Old Feb 3, 2011 | 05:27 PM
Pocket's Avatar
Pocket
You don't even have to remove it. It takes 10 seconds to disable it. Look underneath the turbo at the pedestal the turbo is mounted on. There is one electrical connector on the pedestal itself. Unplug it, and your EBPV is disabled.
I deleted my EBPV a few years ago. It was more annoying than useful in cold weather.
Old Feb 3, 2011 | 05:36 PM
Ducci's Avatar
Ducci
What do you mean?
Old Feb 3, 2011 | 05:50 PM
Pocket's Avatar
Pocket
What do you mean?
My exhaust backpressure sensor tube kept getting clogged. As a result, the sensor couldn't read backpressure, and the EBPV wouldn't disengage when I hit the accelerator. It wasn't fun having a top speed of 20 mph. That and I really didn't like having to maintain keeping the sensor tube clean, so I disabled the EBPV. Later I found a great deal on an EBPV delete outlet and turbo pedestal and made the swap.
Also with a 4" exhaust the EBPV gets pretty loud in the driveway. I'm sure my neighbors didn't like me much when I cranked the truck up in the early AM hours.
Old Feb 3, 2011 | 06:02 PM
Ducci's Avatar
Ducci
Nice, I will for sure keep all of that in mind. Planning on going to a 4" system soon.
Old Feb 3, 2011 | 07:36 PM
SkySkiJason's Avatar
SkySkiJason
I like the fast warm-ups with EBPV. It will even close after truck has idled for a bit in REALLY cold weather - keeping combustion chamber temps up for a good burn, and keeping my toes warm too! (it is pretty loud with a straight pipe)
I have to admit, it never activated the whole time I lived in FL.
Old Feb 4, 2011 | 01:47 PM
badhabit1's Avatar
badhabit1
Really can't tell any difference in warm up times with mine. Been below zero hear lately. Truck has always been slow to warm up, but that's normal. Gas mileage is better with it disabled, not choking my truck for the first 5min of driving anymore!
Old Feb 4, 2011 | 04:53 PM
JT250's Avatar
JT250
I cant tell a difference on warmup either. Mine warms up pretty quickly, but I keep it plugged in when it gets cold enough.
Old Feb 9, 2011 | 02:34 PM
Ducci's Avatar
Ducci
Sense this thread stated the other day I have been thinking with my short drive to work and warm up I am wondering if I can pick up some mpg with it off instead of coming on and off like I guess they do while you drive? It has been in the 30’s here in the mornings (I know warm compared to the rest of the county). I usually let the truck warm up for 3-5 minutes while I go back in the house and get coffee and finish getting ready for work. Do you think I would see any improvement in gas mileage or maybe drivability when it is disconnected and cold?
Old Feb 9, 2011 | 02:40 PM
JT250's Avatar
JT250
You would definetly see a differance in performance when it is "cold". It has been colder thn that here and mine has been unplugged. MPG....possibly.
