Non powerstroke converting to powerstroke questions
Its been a cold week so ive been doing a lot of thinking and came up with a few questions. I am looking at purchasing a 1990 F250 with an e40d and a N/A 7.3 L with a what i think has a bad oil cooler problem. So it got me to thinking about buying this truck and putting in a 7.3L powerstroke and wondered what kind of things i might run into and have to change and if it is even worth it. I have been told of a place i can buy a good running powerstroke engine with everything minus turbo for $550. So thats not to bad in my book. I would have thought there would have been several threads on it but i havnt found anything. So what all would i have to change?
I would ask the same question here: 1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You would have to change the PCM (if it even bolts up) and I would imagine the main harness or modify and add to it. It is a heck of a project to enbark on, please let us know what you decide and how it goes.
https://www.ford-trucks.com/forums/9...p-started.html Click on this link. This thread is the daddy of them all.
Sorry guys i need to clarify myself a little bit i guess. The truck im going to purchase already has a 7.3L Diesel but its a 1990 model which we all know is N/A. I would like to replace that motor is a true powerstroke with a turbo.
I know you can add a banks to a 1990 model diesel but their is someing about a 95-97 powerstroke that just purs like a kitten!!!!
I hope this helps with what i think might be some confusion.
Received 3,108 Likes
on
to convert the 90 from an IDI to a powerstroke, you will need to change the engine, complete engine bay and in dash wiring harness with computer, dash cluster, and you will also have to install a vehicle speed sensor somewhere because the powerstroke uses a VSS, the 90 uses a cable driven speedometer.
it can be done, but it would be easier and cheaper to just buy a running powerstroke powered truck if you really want a stroker.
if it was me, i would fix the oil cooler on the 90, and look for a used banks or ats turbo setup.
on
AntiHero55
64
05-27-2016 08:31 AM
20powerstroke02
01-09-2013 12:17 PM
HootieMcGrudy
05-28-2008 09:24 AM
1996, 60, 73, 97, convert, converting, ford, forum, instrument, international, panel, powerstroke, problems, turbo, wiring
