re:TSB 10-23-9
Old Feb 2, 2011 | 10:14 AM
Nipperdog's Avatar
Nipperdog
re:TSB 10-23-9
I had my truck reflashed today under TSB 10-23-9 due to harsh 2-3 shifting when cold. The truck now shifts much smoother and has already gained .25mpg. The downside is that the displayed shift status bar is no longer displayed while driving similar to the way it was before the 400/800 upgrade. I really don't care about the status bar and can live without it. Just wondering if anyone else had a similar experience loosing the shift status bar after the 10-23-9 reflash?.
Old Feb 2, 2011 | 10:17 AM
RaiderAZ's Avatar
RaiderAZ
Smile
I had the flash done and noticed the same problem. I turn it on and it has been on since then and that was back at the first of December.
Old Feb 2, 2011 | 10:23 AM
Marauder92V's Avatar
Marauder92V
Are you talking about the gear numbers next to the LCD display? I not 100% sure how to do it, but I know my Job 2 truck showed up without the numbers on the right side. One of the fine contributors told me that I needed to do something to get them to show up. I just can remember what it was
Is it simply to used the manual shifting capability?
Old Feb 2, 2011 | 10:28 AM
RaiderAZ's Avatar
RaiderAZ
On your gear shift press the + button.. That will turn it on. Just leave that way and you will see it comes on every time you start the truck.
Old Feb 2, 2011 | 10:37 AM
Marauder92V
That's it! I knew it was something simple. And to turn it off, just do the + again?
Old Feb 2, 2011 | 11:01 AM
Nipperdog's Avatar
Nipperdog
Right on: Thanks for the info. When I picked up mine after the 400/800 flash it was already working. The service tech must have turned it on. I never touch the manual shift buttons.
Old Feb 2, 2011 | 11:08 AM
Sgt93's Avatar
Sgt93
Just hit the little plus button and it should come back on.
Old Feb 2, 2011 | 05:32 PM
kper05's Avatar
kper05
Yes when you get this TSB flash (PCM/TCM) it will disable your shift numbers but once you turn it back on, it will stay on (same as the 400/800).
rdenis
6.7L Power Stroke Diesel
19
Mar 14, 2011 10:15 PM
gascan
27
Feb 28, 2011 10:53 PM
ruschejj
Jan 20, 2011 10:17 AM
rcklnhunter
Dec 5, 2010 04:58 PM
frt2599
Dec 2, 2010 11:04 PM
