Sponsored by: Real Truck
another crazy conversion guy!!!
Old Feb 1, 2011 | 02:14 PM
long79crew's Avatar
long79crew
got a beat up 94 ford crew long bed 4x4 powerstroke with a good frame/drivetrain, and a 79 crew long bed 2wd with an excellent body(needs paint) anyone ever heard of a 79 body swap onto a newer 4x4 frame like this, both trucks are complete........how bout it?
Old Feb 1, 2011 | 02:29 PM
cparks's Avatar
cparks
We did sort of the opposite back in the mid 90's putting an 89 F150 2 wheel drive body on a 89 F250 4 wheel drive chassis. Ended up putting a 429 in the truck and ran it for years before selling it. It was a bit of work with the mounts, but looked good.
Old Feb 1, 2011 | 02:30 PM
ontariofarmer's Avatar
ontariofarmer
With torches and a welder....anything is possible
Old Feb 1, 2011 | 03:28 PM
ghanson's Avatar
ghanson
Veteran: Marine Corps
SpikeTV's Power Block dropped an old 70's Ford Crew Cab onto a Dodge 4x4 diesel chassis. It isn't too hard to do, you just have to make sure that the wheel bases are similar if you're looking to drop the old body onto the new frame. If you go to the SpikeTV website you cann find it. I believe they called it the "Super Dually." I'd kill to have an old crew cab but they impossible to find anymore!
Old Feb 1, 2011 | 03:29 PM
long79crew's Avatar
long79crew
what kinds of problems did u run into? im thinking big here,im hoping i can stuff all that componentry under that body,im an interstate trucker, so my work time is limited, hope to have it completed in a year or two...
Old Feb 1, 2011 | 03:33 PM
long79crew's Avatar
long79crew
www.oldfordcrwecabs.com....there are a plethera of old crews for sale there.....Have fun
Old Feb 1, 2011 | 03:57 PM
ghanson's Avatar
ghanson
It wasn't my project, I just watched the show and took notes. I know they have all the information about the build online including the companies they got parts from such as replacement wiring harnesses and such. I'll see if I can send you a link in a bit. And thanks for that site! I'll have to check that out!
Old Feb 1, 2011 | 06:32 PM
cparks's Avatar
cparks
For the most part the body fabrication to the frame was not too bad, the front bumper was a bit of work and actually cut off part of the old frame and welded it to the new frame. The steering shaft was a little work too.
NIdude
Sep 28, 2013 09:05 PM
crazed87bronco
Jan 24, 2011 08:53 PM
OZZY1833
Jul 4, 2010 12:01 AM
tahleel
Jan 24, 2009 08:37 PM
rhenson1
Jun 24, 2005 01:40 AM
