question on frame interchange
Old Jan 19, 2011 | 12:26 AM
crazed87bronco's Avatar
crazed87bronco
Just going over ideas and thought of this does a 71 crew cab 4x4 short bed use the same frame as a long bed f250 4x4? If not what's the difference between them in lengths? Thinking of instead of swapping all the goodies off of 79 f250 4x4 why not just set my body on the 79 frame.
Old Jan 21, 2011 | 06:27 PM
wuck's Avatar
wuck
*Edit* Wheelbase info
*Edit* Corrected Info 2/7/2011
67-72 Bumpside trucks:
Reg cab short bed 115" (I)
Reg cab long bed 131" (V)
Crew cab short bed 149" (V)
73-79 Dentside trucks:
F100/150 Reg cab short bed 117" (I)
F100/250's Reg cab long bed 133" (V)
F350 Reg cab long bed 137" (I)
Super cab short bed 139" (I)
F350 Super Camper & Trailer Specials Reg cab long bed 140" (I)
Crew cab short bed 150" (I)
Super cab long bed 155" (I)
Crew cab long bed 166.5/167" (I)
(V)= I have verified from vin tag
(I)= Internet Source, mostly FTE
https://www.ford-trucks.com/forums/8...s-covered.html
You may also have a rear frame width difference to deal with, but that's not difficult.
Frame splice conversion:
Old Ford Crew Cab Community, Pre 1980 Ford Crew Cab owners community and information source.
You may want to poke around the Old Ford Crewcabs website for a while, those guys have done what you want to do.
Pat
Last edited by wuck; Feb 7, 2011 at 08:05 PM. Reason: Additional / Corrected Information on Wheelbase Numbers
Old Jan 21, 2011 | 07:48 PM
4x4jedi's Avatar
4x4jedi
Those are the wheelbase numbers arnt they?? I think what he needs is weather or not he can cut the rivets mounting the rear supention hangers and move them to the short wheelbase locations??
Old Jan 23, 2011 | 11:51 PM
crazed87bronco
What I am asking is there any 78-79 4x4 f250's that have the same wheel base as my 71 crew cab 4x4? I ask this because instead of swapping the power steering, front disc brake axle, 460 engine, and the power brake setup off of a 78-79 donor truck and sticking it on my 71 crew cab can I find any 78-79's with the same wheel base as my crew and just put my body on the later frame? Sorry for any confusion
Old Jan 24, 2011 | 01:27 AM
wuck's Avatar
wuck
Only another crew cab, which of course doesn't really help you.
Most people swapping frames under a crew cab want to go from 2wd -> 4wd (Like Me!), which is what I thought you were trying to accomplish.
The wheelbase numbers I listed are for both dent and bump side trucks, 1967-1979.
Pat
Old Jan 24, 2011 | 08:53 PM
crazed87bronco
Thanks for the frame measurements I'm guessing the supercab with longbed frame would be to short if I converted my short bed crew into a longbed? Making the rear tires sit to far forward in wheel wells am I correct? Or would they be centered in the wells? I forget how much longer the front half of the longbed is compared to the shortbed
kadrocker
WTB - Ford Trucks & other vehicles
Jul 8, 2014 10:46 AM
Hickfied
Apr 6, 2010 10:06 PM
79man
Jun 8, 2008 12:57 PM
njtinman2
Feb 8, 2005 12:16 PM
cannonfodder
Apr 5, 2004 07:20 PM
