another leak!
Old Feb 8, 2011 | 06:16 PM
  #31
jp1gt's Avatar
jp1gt
I got the damper on! Everything was tough, I used some good sticky wheel bearing grease to keep the copper washer on first of all. Then I screwed on as tight as I could by hand, then used the punch to tap in on a little tighter. I cut the 1 1/16 wrench a couple of times and bent it with a torch a couple of times. I think it would be easier to just take the fuel pump off at the same time except I did not want to mess with the hoses. It is BONE DRY now!!!!! I still can not figure out what threads they are. Next time I go to the hydraulic store, I will bring it with me, but it may be a while.
Old Feb 8, 2011 | 06:53 PM
  #32
Copedawg's Avatar
Copedawg
I can't find the exact thread but I THINK I remember 1/4" NPT...I could be wrong
Glad it is all dry! You should notice better MPG's!
Good job!
Old Feb 8, 2011 | 06:59 PM
  #33
Copedawg's Avatar
Copedawg
Good job!!! Can you get a pic of the custom wrench for us/me?
Old Feb 8, 2011 | 07:43 PM
  #34
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
X2 on that and also the pic of the downside of the Dampener please
Old Feb 8, 2011 | 09:16 PM
  #35
jp1gt's Avatar
jp1gt
It can not be pipe thread as it tightens up against the washer. It looks alot like the banjo threads. I have a genie boom that has weird threads on everything also, this hydraulic stuff drives me nuts!The weather here in northern ca is sooo good right now I am taking advantage of it and working outside as it won't last forever! I will take some pics as soon as I can.
Old Mar 2, 2011 | 12:49 PM
  #36
jp1gt's Avatar
jp1gt
I have a pic of the wrench, but I can not figure out how to post it on this forum.
Old Mar 2, 2011 | 01:00 PM
  #37
Copedawg's Avatar
Copedawg
upload it to your album click on your name in the upper right. While you are there make a signature
Old Mar 2, 2011 | 01:21 PM
  #38
jp1gt's Avatar
jp1gt
OK, I made an album, but I still don't see where to add it to the post
Old Mar 2, 2011 | 01:27 PM
  #39
Copedawg's Avatar
Copedawg
OK, open 2 windows. one with your album and the other here on the reply (make sure you are on "go advanced").
Open the picture you want to post. At the bottom you will see "addresses" copy the top one. Now click the "insert image" button in the other window. a window will drop or pop up...now paste the address in there and see what happens. I will look for the results
Old Mar 2, 2011 | 01:39 PM
  #40
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Or you can send the pic via e-mail to some member here and he upload it for you.
Old Mar 2, 2011 | 01:43 PM
  #41
Robbgt's Avatar
Robbgt
Or we could pull it from your album and post if for you
JP1GT's wrench
Old Mar 2, 2011 | 01:45 PM
  #42
jp1gt's Avatar
jp1gt
I found the advanced---Thanks for posting the tool---------the notch is to tap on the wrench with the chisel punch to get the final tightening.
Old Mar 2, 2011 | 01:56 PM
  #43
Copedawg's Avatar
Copedawg
Looks great! so does the sig!
Old Mar 2, 2011 | 02:01 PM
  #44
jp1gt's Avatar
jp1gt
I at least got a pic of the truck on the avatar. I have an ad in the classified but did not get a bite. I wanted to give the forum guys first crack at it. For what I am asking, it is not much more than the engine cost my wife! Thanks for the help.
Old Mar 2, 2011 | 06:43 PM
  #45
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
JP1GT's wrench
Rob, you are the PERFECT SPY. LOL.
How did you do that? Where is his album?
fixitman1310
13
Apr 26, 2011 03:10 PM
przao1157
May 1, 2009 04:18 PM
TPM
Jan 16, 2009 12:47 PM
jmaskew
Dec 4, 2008 09:38 AM
stroker393
Dec 1, 2004 10:09 AM
