I just noticed antifreeze on the back of the engine by the starter and at the bell housing could this be intake or is there a coolant line in the back I don't see a line but you never know
Take some starter fluid and spray it around where the gasket is while the truck is at idle and if there's an intake leak, the idle will go up because itl suck it in. If it's not that, keep the truck running and start the meticulous search for a leak from any part of the motor where coolant flows.
You need to put a pressure tester on it , then have a look with a good flash light , you may have to climb on top of the motor or go under it , it could be runing from any where , there are heater hoses , freeze plugs in that general area , could be the intake gasket to....Lew
Found out where the leak is a freeze plug on the back of the engine sucks!!!
You can "rent" a pressure tester from Oreilly for nothing for either 24 or 48 hours. I found the leaks where I hadn't thought of. Also, I think Advance does the same as far as "renting" the leak tester.
