Antifreeze leak
Old Sep 14, 2011 | 07:14 AM
4CFarms's Avatar
4CFarms
Antifreeze leak
What im planning to do this weekend is replace the hoses from the radiator to the waterpump, and i want to drain all the antifreeze and put new antifreeze in, is there anything i need to be aware of or can i just drain it, put the new hoses on and fill it back up?
Old Sep 14, 2011 | 12:25 PM
liv's Avatar
liv
Here's the procedure for a 6.0. Same principle just different fluids.
Beachbumcook 6.0L Coolant Flush Procedure
With The Addition of VC-9 Engine Cooling System Iron Cleaner and 69cj Thermostat Removal Option
BBC does it every 50,000 miles just because it is fun to do and he is **** about maintenance. PLEASE NOTE THE MIN LEVEL ON THE DEGAS BOTTLE IS NOW THE NEW FULL LEVEL.
1) Buy Four (4) gallons of Ford Premium Gold Coolant (or Zerex G05), Two (2) bottles of VC-9 and one (1) Thermostat O-ring (if removing T-stat) at dealer.
2) Buy 15-18 gallons of DISTILLER WATER at local grocery store.
3) Open Radiator Stopcock and/or Drop lower radiator hose until radiator is empty.
4) Close stopcock and/or reconnect hose.
5) Add 2 bottles of VC-9 to degas bottle (The VC-9 is in the Ford procedure for flushing prior to water flush and new coolant). Add distilled water until the degas bottle is at MIN. Go for a 20 to 30 mile drive (Some say you need to drive at temp for 1 hour to fully clean system). Drain system, then proceed either with or without Thermostat.
Thermostat Removal Option: (Thank you 69cj)
A) Pull air cleaner assembly.
B) Drain coolant (See step 3 above).
C) Remove upper radiator hose.
D) Remove 2 nuts on t-stat housing.
E) Lift and move press sensor bracket to the side. Not a lot of play in it but it will move.
F) Remove 2 more nuts on t-stat housing.
G) Remove housing. It will lift right off of the studs.
H) Reverse procedure to re-install. Use a new O ring (5 bucks at dealer). I used Vaseline to hold the O ring in place. Tighten nuts to 23Nm (17lb/ft).
6) Add distilled water to degas bottle until it reads MIN.
7) Drive vehicle with heater on HIGH (HOT) until temp gauge goes to normal and thermostat opens (Excursion owners Do Not Forget Rear Heater). If thermostat is removed just idle for 5 minutes gently varying idle rpm’s between 750 and 1500 or turn High Idle Mod on.
8) Repeat steps #3,#4, #6 and #7 no less than 4 or 5 times until drain water is clear.
9) You now have 100% distilled water in your system.
10) Drop lower hose 1 last time, drain and reconnect. Reinstall Thermostat if removed earlier.
11) Look in manual to verify your system capacity (27.5 quarts) and add 3½ gallons of FULL STRENGTH Ford Premium Gold (or Zerex G05) coolant into your degas bottle.
12) Start motor and add distilled water to bring system level to not exceed the MIN Mark on degas bottle. PLEASE NOTE THE MIN LEVEL ON THE DEGAS BOTTLE IS NOW THE NEW FULL LEVEL.
13) Drive truck around to open thermostat and let cool once or twice to purge any air. May need to add more distilled water (don't add more coolant)... but when done you have flushed your entire system and have a perfect 50/50% concentration of coolant and distilled water.
Old Sep 14, 2011 | 10:32 PM
4CFarms's Avatar
4CFarms
what and where is the degas bottle and whats it for?
Kdr358
Oct 15, 2012 09:20 PM
MageBeowulf
Dec 30, 2011 01:58 PM
ABuzzard
Dec 3, 2008 03:41 PM
71FoMoCo
Aug 8, 2006 02:01 PM
Fair 96
Jan 25, 2005 11:06 PM
