Floor pan help
Old Jan 30, 2011 | 10:35 PM
gthiboy's Avatar
gthiboy
Floor pan help
hey guys, I was wondering how far gone is too far gone on floor pans for our trucks?
I knew the floors were pretty soft when I got this truck but today I was playing around with it and pulled up the rubber mat and insulation and the floors are pretty much gone. mostly on the far sides of the cab(i think the windshield has been leaking for a long time).
where are all the places I should be concerned about replacing? any recommendations on replacement parts? I found a place close to me called certifit that I can go to their warehouse and pick up pans for $35 a piece.
I'll post up some pics tomorrow to help show what im dealing with.
thanks, kyle
Old Jan 30, 2011 | 11:06 PM
JustBlaze's Avatar
JustBlaze
https://www.ford-trucks.com/forums/9...storation.html
Take a look at that thread if you want an example of what can be fixed, basically rebuilt the bottom part of the cab.
Old Jan 30, 2011 | 11:47 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's more from rust from water/salt underneath, and built up water from under the mat either from spilled crap, condensation and leaks. Not likely the windshield, but the cowl, windshield wiper mounts and heater core.
Josh
Old Jan 31, 2011 | 06:42 AM
grinnergetter's Avatar
grinnergetter
Sweet...wait....does this mean I'm famous or dumb.
Old Jan 31, 2011 | 08:54 AM
JustBlaze's Avatar
JustBlaze
It means you do awesome work. I figure if he saw what you did he would think anything is possible.
Old Jan 31, 2011 | 09:43 PM
gthiboy's Avatar
gthiboy
here are some pics, what parts do you pro's see that should and can be replaced?
Old Jan 31, 2011 | 10:00 PM
duncare's Avatar
duncare
I have a 79 F250 supercab. It has the same rust problem. I got my floor pans from LMC truck. The driverside is in, the passengerside hopefully will be by the end of the week. Luckily I have access to a welder.
Old Jan 31, 2011 | 11:14 PM
JustBlaze's Avatar
JustBlaze
Your gonna need floor pans but you obviously already know that. Try and get a shot of your cab mounts underneath if you can to see how those are.
Old Feb 1, 2011 | 07:38 AM
grinnergetter
Floor pans are obvious...now what you need to have close look at is,did the rust get up the side panels. You need to have something to weld to there. Thats is where you have to get creative.
Dont forget to leave the drain channels on your cab mounts clear of any welds. From the looks of it your going to need new cab mounts and now is the time to do it.
Get some weld thru primer to coat you parts before welding them in. Use seam sealer on everything you welded in.
If you are not going to take it that far...when you cut out the old pans make sure you leave some of the original metal near the side panels to weld to.
When I had mine apart I put rust prevent in a pump up sprayer and shot it in every nook and cranny I could get to. Take the plugs out of the doors and remove the headliner. Then you can spray the RP down into the cab corners and bottoms of doors, and front pillars.
Old Feb 1, 2011 | 02:16 PM
gthiboy's Avatar
gthiboy
here are some pics of the mounts. to me they don't look too bad but thats not saying much.
driver side
pass. side
Old Feb 1, 2011 | 02:47 PM
bucks77ford's Avatar
bucks77ford
Those cab mounts actually don't look bad. You'll be able to tell more when you get the old floor pans off. It also looks like most of the rocker panel on each side is OK. The floor pan width may be cutting it close to weld back to the rocker, but you should be OK, but you won't know til you get the pan laid out. Get the rust cut out first and then see where you are at. You may have to add a bit of "filler metal" but shouldn't be too big of deal.
Old Feb 1, 2011 | 03:49 PM
78 PEB's Avatar
78 PEB
Shoot me a PM........I have some of what you may need. I cant PM you for some reason.
Old Feb 1, 2011 | 06:31 PM
nothercrash's Avatar
nothercrash
My floors looked very similar to yours. Horrible rust on the pans, but my rockers, cab mounts, and cab corners were actually almost clean, like yours.
I wonder what makes that happen, some particular driving style I assume.
Old Feb 1, 2011 | 06:38 PM
bamaf150's Avatar
bamaf150
Like Buck said, your mounts look pretty good but some attention now would be appropriate, clean, primer and paint.
Old Feb 1, 2011 | 06:59 PM
buckin69bronco's Avatar
buckin69bronco
I replaced mine with the cirtifit ones. I don't know how well the LMC floor panel fit but these needed a lot of coaxing to get them to line up.
