Eliminate e40d rear axle speed sensor
Old Jan 29, 2011 | 09:47 AM
503racing's Avatar
503racing
Can i eliminate the rear shift sensor in my axle to run the trans as a shiftable automatic? i have trouble getting into the high end when racing and i think its because all the spinning. granted it is in 4lo so i wont get alot of speed but anything would help and it seems like it has more to give but is revving out. the axles are 3.55 and not sure if they're ls because truthfully haven't looked yet. thanks
BTW forget to mention 1992 F150 Flare side with 302
Old Jan 29, 2011 | 09:56 AM
Conanski's Avatar
Conanski
The rear axle VSS sensor is manditory for proper transmission operation so no it cannot be eliminated. The reason the motor doesn't have any top end power is because it's not designed for it.. peak HP happens at 3800rpm so reving it more is just making noise. If you want more top end HP swap in a Mustang HO cam.
Old Jan 29, 2011 | 10:05 AM
USMC0351fordtruckin's Avatar
USMC0351fordtruckin
when i was lookin at ur truck it was open diffs... try goin down 2 walter's and pickin up a 5.8L 2 swap in they charge bout $300 for a complete engine thats not expensive....
Old Jan 29, 2011 | 10:06 AM
503racing's Avatar
503racing
I'm hoping to do that soon because i definitely want more power out of it, but the budget is tight.(isn't it always?) there are just times it feels like it has another gear to give but i cant get it there, i thought maybe just eliminating that and shifting myself would work out better. the mud is to thick to run in 4hi. so far the motor mods are eliminated the ac, smog, and switched to dual electric fans. the truck is raced off road.
Old Jan 29, 2011 | 10:08 AM
503racing's Avatar
503racing
yeah the 5.8 would be sweet. anything to go fast!
Old Jan 29, 2011 | 10:11 AM
Conanski's Avatar
Conanski
A stock 5.8 won't rev any higher and it's rpm he needs, all the 5.0 needs is a cam and it'll sing to 5500rpm.
Old Jan 29, 2011 | 10:12 AM
503racing's Avatar
503racing
@usmc0351
hey man weird running into you here. lol just went past your place last night and was eyeballing the bronco.haha Still thinkin bout it.
Old Jan 29, 2011 | 10:14 AM
503racing's Avatar
503racing
think your right about the cam, its on the list as soon as i get some more money from my sponsors. do think a set of 4v heads would help out too? i tried to research the 92 motor some but not alot of luck or im not looking hard enough
USMC0351fordtruckin
tryin find a set of axles with 4.10 gears i think that they where in '87-'91 F-150's or weld ur spider gears its not the best but its cheap
Old Jan 29, 2011 | 10:21 AM
503racing's Avatar
503racing
talked to some guys about the "lincoln locker" and they said it pushs to hard in the turns. the 3.55 seems pretty good so far i just want more speed on the straights. i think the 4.10 would get me off the line quicker for sure, but i would hit the same issue on the top end.
USMC0351fordtruckin
the olny engine that i know of where the heads veryied form 2v to 4v was the 351C no the 302 or 351Wbut from what i been reading GT40 heads r what u want
Old Jan 29, 2011 | 10:24 AM
503racing's Avatar
503racing
def.you get a set of gt 40 heads you call . they had 4v on the 84?(around there) mustang gt 302.
Old Jan 29, 2011 | 10:32 AM
USMC0351fordtruckin
i just learning yet but i think the 4.10s would keep u up in ur peek RPMs so u'd be gettin ur peak power and have the gears to move u through that thick mud as well... when my brother swapped 4.10 into his ranger for muddin it made a huge difference in the mud
Old Jan 29, 2011 | 10:38 AM
503racing's Avatar
503racing
i'll chk into it more.
fatheroftwo
Mar 10, 2016 11:56 AM
junkyardjeff
May 30, 2015 08:24 PM
Ford_F350SD
Jun 14, 2013 03:20 PM
ROBZ95XJ
Dec 3, 2012 05:10 PM
Duct Tape Racing
Oct 12, 2010 12:46 PM
