Grease Zerks on upper ball joint
Couldn't get to those bad boys with my gun.
This solution worked for me.
Original: Ford Truck Enthusiasts Forums - wpnaes's Album: Various Ex Work - Picture
Improved: Ford Truck Enthusiasts Forums - wpnaes's Album: Various Ex Work - Picture
Check to make sure you have good clearance between the knuckle and zerk. Ford Truck Enthusiasts Forums - wpnaes's Album: Various Ex Work - Picture
Amazon.com: Thexton 418 Right Angle Grease Coupler: Automotive
I tried the 90* zerks I had in my garage and couldn't get any of them to work where I felt there was enough clearance. I went to my local mom and pop auto parts store and bought a Lincoln model 5883 fitting, works great. I do lift the wheel off ground when I grease the ball joint as you do need to move uninversal out of the way. Here's a pic, Ford Truck Enthusiasts Forums - RobRoss's Album: Grease Gun Fitting - Picture. Hope this helps some of you guys.
Thank you.
Thank you.
Thanks everyone for the inputs. I purchased my 90 zerks from O'Reilly auto parts - they came in a box with 10 or so normal, 45 deg and 90 deg fittings. I'll look up the part number tonight. There must be some variation among ball joints or knuckle sizes as mine, though close, don't rub.
Question, why not a grease zerk on the bottom ball joint? Would they get knocked off by bushes, etc?
It is that simple, I greased the drill and tap. It's been 15-20k miles since I did mine and no issues. The ball itself has a flat area on the bottom, so drilling the exact middle is not critcal. What I mean is if you set the ball on a table, it would stand and not roll over. Let me know if you have questions.
labgraphics
03-28-2012 05:58 AM
