Sponsored by: Real Truck
4x4 and braking problems
Old Jan 29, 2011 | 12:34 AM
Chaosracing's Avatar
Chaosracing
Okay here is my problem. I stared to notice my truck pulling to the left while braking. Now I read thru the forums and found one thing mentioned....hubs. I know its not the caliper (less than 1 yr old) and I just lubed the slide pins when I replaced the hub assembly. I have the hubs locked (manuals) so I will unlock and see if thats it. But I also noticed with all the snow we have been getting that when I shift out of 4x4 (manual transfer case) that the 4x4 stays lit and I can tell its still in 4x4. Last 2 times I had to shift back into 4x4 and then shift out of it again. Could the hub be causing this issue as well??
2002 F250 V10 Solid axle leaf spring front end.
Old Jan 30, 2011 | 11:03 AM
Chaosracing
Bump Bump Bump
Old Jan 31, 2011 | 09:30 PM
Chaosracing
Okay, so I know its not the hubs, I drove it around all day today with the hubs unlocked and still get the same problem.
Old Jan 31, 2011 | 10:17 PM
DPorter's Avatar
DPorter
how are the axle u-joints?
Old Jan 31, 2011 | 10:45 PM
99f350sd's Avatar
99f350sd
That would be the rt fr caliper not working..
Old Feb 1, 2011 | 12:21 AM
Chaosracing
U joints are in perfect order
Anyway to test the right caliper?
Dont want to throw money at it without knowing if it really is bad, or if something else is bad.
Old Feb 1, 2011 | 08:14 AM
99f350sd's Avatar
99f350sd
Take caliper apart and inspect..Drive and see if one rotor gets hotter than another..Usually if pulling to one side that side is working and the other side isn't.
Dick
