292 distributor question
Old Jan 28, 2011 | 01:42 PM
Gregs64F250's Avatar
Gregs64F250
I need some help identifying my distributor in my 64 f250 with a 292. The numbers on it are FDJ 12127 C2(?) I need a vacuum advance canister. The one I ordered for a 64 292 from LMC is not correct. Any help would be greatly appreciated!
Old Jan 28, 2011 | 03:38 PM
charliemccraney's Avatar
charliemccraney
FDJ doesn't sound correct to me but I'm not sure. Can you post a picture? You don't need to mail order the vacuum advance. Your favorite parts store should be able to get it. Go to Napa's site and look at the pictures to see if you can find one that looks right.
Old Jan 28, 2011 | 03:43 PM
Gregs64F250
After doing some research, it appears this distributor is off a 1955 Ford 272 V8. Mac's has a new listing for a vacuum advance for a dist. with this number. Still not sure though...
Old Jan 28, 2011 | 04:04 PM
charliemccraney
When the cap is off, do you see two advance springs, among the points and condenser?
Old Jan 28, 2011 | 04:13 PM
Gregs64F250
Yessir, 2 springs.
Old Jan 28, 2011 | 04:39 PM
charliemccraney
That is a load-o-matic distributor which very well could be from a '55. I am almost certain it's not correct for your '64. I think the best course of action will be to get a remanufactured distributor. They too are available from your favorite local parts store. You will also need a cap and rotor because they do not interchange with the load-o-matic and they do not come with the reman distributor.
Do you know if it still has the stock carburetor? If the load-o-matic actually functioned properly, then it also has the wrong carburetor, at which point I'd guess that the engine was simply swapped for an earlier one.
Old Jan 28, 2011 | 05:00 PM
CTom's Avatar
CTom
Store Locator | NAPA Online
Old Jan 28, 2011 | 07:08 PM
Gregs64F250
The carb is a motorcraft 2100. The truck idles fine but backfires thru the carb when accelerating which started me looking at the vacuum advance which was not working. Now here's a million to one shot question...would a dist from a 64 289 work?? I have a couple laying around the shop.
Old Jan 28, 2011 | 07:23 PM
312's Avatar
312
no.........
Old Jan 28, 2011 | 07:42 PM
Gregs64F250
Worth a shot... well looks like I'll get a new one. Thanks for all the help!
john jamieson
Aug 28, 2015 08:35 AM
patmedic
13
Jan 17, 2011 08:18 AM
auerdoan
19
Oct 30, 2010 12:00 AM
64F-100
Nov 5, 2008 06:38 AM
Fordracing64
Mar 23, 2006 12:59 PM
