Which Suspension???
Old Jan 27, 2011 | 05:32 AM
H_A_S_R's Avatar
H_A_S_R
Which Suspension???
I'm getting ready to start my `58 stepside project. I've got my donor Mark VII that will give up it's engine, trans, rearend, and some of the interior. I thought my decision to use the CV front suspension was final. It's not. It's just too wide IMO. I'd rather not be limited to rim choices because of the offset required. I've looked into Volare, but don't want torsion bars. I've checked out the Dakota IFS, but the company no longer makes the swap kits. Rangers and S10's are too narrow. I know guys have made the Aerostar work by adding pieces to the frame and tilting the rack back, but is this the way to go?? I've also seen guys start on the Lexus SC400 swap, but I've never seen one finished. I don't really want to go with the MII on this truck. I'd rather use something a little beefier. I have no problems fabricating what is needed to make something work, I've done many IFS swaps before. I'm just stumped this time......
John
Old Jan 27, 2011 | 06:18 AM
fergusonicford's Avatar
fergusonicford
How about Jag?
Old Jan 27, 2011 | 06:32 AM
48 Steel's Avatar
48 Steel
Got to the search function here and look for IRS or IFS. There is information on both.
________________________________________
46 Ford Tudor - Street Rod
48 Ford F1 - Custom
"If you drive a Chevy, you need a Goodwrench"
Old Jan 27, 2011 | 08:11 AM
Harrier's Avatar
Harrier
This sticky thread: https://www.ford-trucks.com/forums/6...-articles.html
has several articles on IFS install. I recall an article that compared the pros and cons of several different options.
Found the article, it is in many parts. Here is part one.
Front Suspension Alternatives for 1948 - 1960 Ford Trucks, Part One .: Articles
Old Jan 27, 2011 | 05:09 PM
arrowheadfred's Avatar
arrowheadfred
ifs
TCI has a nice MII IFS Thats what i used on my 51
Old Jan 27, 2011 | 06:23 PM
H_A_S_R's Avatar
H_A_S_R
Trying to take in all of this new found info. Thanks for all of the input!
John
Old Jan 27, 2011 | 06:30 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
He said that he did not want the mustangII
Old Jan 27, 2011 | 06:39 PM
arrowheadfred
MII
Guess i should read before i speak. hum BOB LOL
Old Jan 27, 2011 | 07:59 PM
H_A_S_R's Avatar
H_A_S_R
I've found alot of info on the Jaguar swap, I like what I am seeing! The local U-Pick junkyard has 1/2 price days on Wednesday and Sunday. Time to take a walkabout.....
Old Jan 28, 2011 | 10:30 AM
GreatNorthWoods's Avatar
GreatNorthWoods
John,
Two questions come to mind. What do you have against torsion bars and what's not beefy about MII (aftermarket, of course)? I've used Volares in two trucks and I love the torsion bar setup because it's inexpensive, beefy, and it eliminates the need to experiment with coil springs...just set the T-bar height and ride. It provides a nice smooth ride. As far as the MII is concerned, I've seen the aftermarket units used under some very heavy vehicles...some much heavier than your truck. Sure, the stock units were lightweights but the aftermarket MII kits are plenty beefy. The only reason I didn't use one under my truck is the expense. The resemblance of the aftermarket MII to the original is nil! They call them MII suspensions only because they slightly resemble the originals but they are really a totally different suspension.
Old Jan 28, 2011 | 05:37 PM
H_A_S_R's Avatar
H_A_S_R
Originally Posted by GreatNorthWoods
John,
I totally agree with you on the MII suspension. I've built many early Fords and Chevy's with them. The torsion bar setup, however, I am not a fan of. I don't care for the bars hanging under the vehicle, plus, I am looking for something that I can bag. I am keeping the bags on the Mark VII IRS, so it only makes sense to bag the front also. I am looking for something different this time. I am looking for something with big brakes, a swaybar, turn-on-a-dime handling and a track width more compatible with the truck than the Crown Vic. All of these things are "options" when building a MII. They are great suspensions, but I don't want to spend a ton of money to get those options. So now I am looking at alternatives. The Jag seems to be getting closer to the top of my list. I also saw somewhere that someone was considering a Lexus IFS. I'd like to see this swap finished. I appreciate all of the feedback on this subject!
John
Old Jan 29, 2011 | 08:20 PM
H_A_S_R's Avatar
H_A_S_R
After Reading my posts I realized that I typo'd twice. I am using a Mark VIII donor car with 4.6 DOHC and IRS, not Mark VII.....
Old Feb 2, 2011 | 12:20 PM
48 Steel's Avatar
48 Steel
If you haven't already checked out my Gallery, do so. I have installed the Mark VIII IRS and the Jag IFS.
48 Ford F1 - Custom
"Hot Rodders- America's First recyclers"
Old Feb 2, 2011 | 12:28 PM
Bdox's Avatar
Bdox
Yes, I have looked at your gallery before with great interest. Great job, and very helpful to others. Thanks. Good presentation.
Old Feb 2, 2011 | 02:21 PM
CharlieLed's Avatar
CharlieLed
There is a way to control the ride height on a torsion bar front end...I have never seen it done before but my electrical engineering background tells me that it can be done. I would use a stepper motor with a gear reduction at the torsion bar height adjustor...just like you control the height of a bag with air you could control the tension on the torsion bars with an electrically adjustable mechanism. On aircraft the flaps and other flight control surfaces are controlled by such devices.
