Getting Ignition out
Old Jan 25, 2011 | 10:59 PM
k_conner's Avatar
k_conner
I found a guy who is parting out his 97 PSD. I am thinking about taking his ignition and door locks since mine have seized up and I cant unlock them from the outside with my key anymore. I went to ford but they wanted way too much moola. Is it a difficult task to get the ignition out of the steering column?
Old Jan 25, 2011 | 11:19 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Nope theres a little hole under the ignition that has a button or release of some kind that u just have to push then pull out the igintion.
Old Jan 26, 2011 | 05:15 AM
Copedawg's Avatar
Copedawg
Are you sure it is the cores? When you insert the key and turn and you, can see the key rotate in the core even a little, if you can then it is not the core.
We have a lot of problems with our locking mechenisms (linkage). I do not know what exactly it is.
I am banking on some one filling us in on this common problem.
I will pay attention to this thread b/c I need to fix my doors too.
Old Jan 26, 2011 | 11:06 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Never done the door locks, but I did have to change the ignition.. Unhook the batteries. Turn the key to the ON position. Then pull the plastic piece off the bottom of the column and under the ignition you will see the button Blake is talking about, push/hold it in and with the key still in the ON position pull out on the lock cylinder and it will come out. When you install the new one, it will be in the ON position so put it in at the angle that ON would be, once it is on the column, you can turn it back to off. NEVER turn the lock cylinder while it's not installed in the truck unless you don't plan on using it again.
Old Jan 26, 2011 | 11:12 AM
k_conner's Avatar
k_conner
Thanks everyone. Doesn't sound too bad. Strokin, if you only changed the ignition and not the door locks do you now need two keys. One for the doors and one for the ignition? Guess that wouldn't be too bad either though.
Old Jan 26, 2011 | 11:44 AM
thefonz#1's Avatar
thefonz#1
turning the ignition lock while out of the vehicle won't mess anything up unless you release the retainer and turn it the wrong way and pull it out. Even then, it can still be put back together
Old Jan 26, 2011 | 11:46 AM
YoungFordAddict66
Yea see travis knows more than i do haha good thing the dealer replaced mine when i bought it, they said it would be a 5 min job to just push a button an replace. but good luck. and yea ur going need 2 keys. i kinda like having that incase i lose one it will either not start or open the truck, it never does both if i lose one.
Old Jan 26, 2011 | 01:26 PM
strokin'_tatsch
Yeah, I have 2 different keys right now, but I'm going to pull the tumbler and match it up to the stock key that the truck came with. Only reason I'm going to do that is b/c the keys for my F-150 will unlock my truck. Before the ignition got stuck it would also start the truck. My PSD door key will also unlock and start my F-150. So I will have one set of keys for both trucks. LOL. Funny how the keys for both of these trucks are the same key from the factory...
Old Jan 26, 2011 | 02:06 PM
k_conner's Avatar
k_conner
Strokin, that's funny. When I married my wife she had a chevy ( I've now converted her to for) that you could start without a key. Just had to turn the ignition. Her friends knew it and would move it every day at school so she would have to go find it. Haha
Delp73
Nov 5, 2016 07:43 AM
PintoGuy
2004 - 2008 F150
22
Sep 4, 2016 02:14 PM
bgwho922
Jul 13, 2016 09:51 AM
86f250xl
Large Truck
Apr 2, 2015 06:15 AM
RAGaz
Sep 20, 2010 09:40 PM
