Sponsored by: Real Truck
Electronic rust inibitor product
Old Jan 26, 2011 | 11:01 AM
GUNNERDOG's Avatar
GUNNERDOG
Originally Posted by FlameNSky
If you google Motorcycle Tank Rust Removal you will find many articles on the Electrolyte De-Rusting process. Chemically, it turns the rust into simple carbon, actually sealing the metal. I am not sure how it would work without immersing your truck in Saline though.
Electrolytic Tank De-Rusting | XJCD online
Electrolytic Rust Removal From A Motorcycle Gas Tank
Rust is basically just Iron hydrogen and Oxygen... how does one turn those three elements into Carbon, a different element? That is some serious alchemy. This process of removing rust does work, just not as explained.
Regardless, I just can't see how it would work on a truck. Despite what they say this is cathodic protection... they say it is different, but they don't say how it is different... because it probably isn't different.
Old Jan 26, 2011 | 11:50 AM
bubbasz1's Avatar
bubbasz1
Did you read this???
CounterAct Electronic Rust Protection System - Corrosion Control
Old Jan 26, 2011 | 11:53 AM
tigman_tim's Avatar
tigman_tim
To bubbasz1;
I also live in Mich, and would like to know:
how much did you spend? and did you install youself?
thanks,
Old Jan 26, 2011 | 12:35 PM
bubbasz1's Avatar
bubbasz1
I installed myself, it's been like a long time ago but I want to say it was under #300.00.
Easy to install, a little controller I put behind the battery and two stick on >>for lack of a better description I'll call them pads, like what you might have when they check your heart. One in the front of the truck and one in the back, one wire going to each pad if I remember correctly.
Old Jan 26, 2011 | 12:56 PM
GUNNERDOG's Avatar
GUNNERDOG
Originally Posted by bubbasz1
Did you read it?
While CounterAct's electrostatic corrosion control technology can, in a general sense, be considered to be associated with this family of electronic rust protection & corrosion protection methods, CounterAct builds on traditional electronic rust protection technology and CounterAct technology actually begins where traditional electronic rust protection methods leave off.
What? How is it different?
It goes on to reassure you that it IS different, that it WILL work without being submerged in electrolyte, that it IS a novel technology... Then claims that it is different because they got a patent for their device, which is an empty claim...Then they say others have tried to do what they do, but have failed...then they say they have a consulting department... but NOWHERE do they say how it works.
Maybe it does, maybe it doesn't, but their website is not convincing to me.
Old Jan 26, 2011 | 01:04 PM
akorcovelos's Avatar
akorcovelos
sounds like an As Seen On TV infomercial.
Old Jan 26, 2011 | 03:46 PM
bubbasz1's Avatar
bubbasz1
You all just keep up with that undercoating and oil, I'll keep my counteract plugged to the battery and we'll both have rust free trucks. Mines only ten years old, I figure it's going to have to last another ten anyways with the price of the 2011's.
portsample
18
May 1, 2017 12:46 PM
vidaliaman
Paint & Bodywork
Apr 9, 2016 10:53 AM
Anthony487
Feb 18, 2016 10:20 PM
lawdawg79
Jan 27, 2016 05:18 AM
PGS67
Jan 4, 2016 10:45 PM
