Stage 1 injectors
Old Jan 24, 2011 | 12:58 PM
seanlleiker's Avatar
seanlleiker
Stage 1 injectors
I'm looking to upgrade my injectors to stage 1's. If I do this, what, if anything, must be upgraded to assist the new injectors? Currently I have 3"dp with 4" straight pipe, cold air intake and thats pretty much it. Thanks Sean
Old Jan 24, 2011 | 01:06 PM
JamesHajek's Avatar
JamesHajek
Nothing is needed persay... Automatic or manual transmission? Stage 1's with no chip will act just like stock injectors, so you might want a custom tuned chip. I would get gauges on that thing too before you chip it, that way you can keep an eye on temps.
Robbgt's Avatar
Robbgt
you're on the right track with intake and exhaust. In order to monitor what it happening in your engine, it is recommended that you install at minimum a pyrometer to measure exhaust gas temperatures. In general, people go with a 3 gauge A-pillar pod and get boost, pyro, and trans temp (if auto trans), but there are many options and many different gauge configurations available. Clay at riffraff can fix you up Riffraff Diesel
To take full advantage of the 1's, you're going to want a chip burned for your needs. There are multiple vendors available for this including DP-Tuner, Total Diesel Performance, Power Hungry performance etc.. just google any of those to get you on the right path.
If you haven't choose a place to go for injectors Jim @ Rosewood can hook you up
http://www.diy-injectors.com/
Old Jan 24, 2011 | 01:17 PM
Talyn's Avatar
Talyn
You'll get some HP with Stage 1 injectors and no chip, but not a lot. The PCM just doesn't know how to use the injectors unfortunately.
It's worth the upgrade. Better fuel economy and motor efficiency. Go for it.
Old Jan 24, 2011 | 01:32 PM
seanlleiker
I forgot to mention I'm looking at a TW Chip and I do have Rosewood Diesel as one of my favorites. I will look into gauges. The 140V IDM is something else I'm looking into, what resistor do I need. I have elected my dad to do some soldering for me, he does that I don't. Do you guys have a favorite gauge? Sean
Old Jan 24, 2011 | 01:37 PM
Robbgt's Avatar
Robbgt
IDM Mod links:
https://www.ford-trucks.com/forums/8...-140-volt.html
https://www.ford-trucks.com/forums/8...od-w-pics.html
Old Jan 24, 2011 | 02:10 PM
seanlleiker
Thanks i will read up on it.
Old Jan 24, 2011 | 02:23 PM
Talyn's Avatar
Talyn
great, my post didn't post.
Anyways.
The IDM mod doesn't really do anything, your better off doing the FPR Shim mod.
Riffraff Diesel: Riffraff 94-97 Turbo Intake Boot
Intake replacement boot might help you some.
I like the isspro EV2 gauges.
Old Jan 24, 2011 | 05:02 PM
JamesHajek's Avatar
JamesHajek
Anyways.
How much horses does the turbo intake boot add?
Old Jan 24, 2011 | 05:14 PM
jg96powerstroker's Avatar
jg96powerstroker
some one one here had a tw chip for sale, hmm have to look who had it
Old Jan 24, 2011 | 05:22 PM
jg96powerstroker
ok go to the thread more horsees for my ods, 2 page find powerstrokedieselean and pm him he has your chip man!!!
Old Jan 24, 2011 | 07:06 PM
seanlleiker
sweet, i will pm him tonight. thanks for all your help.
Sean
Old Jan 24, 2011 | 07:26 PM
seanlleiker
I must be having a mental block because I am not having any luck finding powerstrokedieselean.
Old Jan 24, 2011 | 07:43 PM
seanlleiker
I finally found it. Thanks
Old Jan 25, 2011 | 12:39 AM
jg96powerstroker
sorry man it was fan, glad you found him!! hope you got a deal worked out on it man
bill wilson
Oct 4, 2014 03:55 PM
sean9049
May 16, 2014 03:12 PM
88f1504x4
Jan 25, 2013 09:33 PM
DIYMechanic
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 8, 2011 12:49 AM
cutlass
Jan 6, 2011 07:47 PM
