C4 problems please help
Old Jan 23, 2011 | 12:13 AM
myklstrng's Avatar
myklstrng
Fluid is coming out of the breather when I drive above 45mph
-76 bronco 302, I bought it like this, no history on motor & trans.
- problem started only after I checked the tranny fluid level, when I saw it was a quart low I topped it off.
- do I have the wrong dipstick & or dipstick tube?
- can I drain the pan, then add only the required amount back in & cut the dip stick tube to the proper length?
- how much fluid should the tranny pan hold?
Old Jan 23, 2011 | 06:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It will blow out of the breather if it is overfilled. When you checked the level was the trans warmed up and the engine idling in park?
Old Jan 23, 2011 | 09:02 AM
myklstrng's Avatar
myklstrng
Yes, & while it was blowing out the breather I would pull over put it in park & recheck it. it would only show a 1/4 inch of fluid on the dipstick & still blow out the breather
Old Jan 23, 2011 | 09:46 AM
jk080's Avatar
jk080
Transmission Rebuilder
Possible wrong dipstick?
Old Jan 23, 2011 | 10:18 AM
myklstrng's Avatar
myklstrng
I agree with you jk080. Is there a part number on the dipstick tube that I can match with the right dipstick?
If I drain the entire tranny or the pan then put the correct amount back in I could just shorten the tube, flare the end & I should be good right?
O
does the pan hold an exact amount, or does it depend on whether its sitting/running?
Old Jan 23, 2011 | 10:57 AM
myklstrng's Avatar
myklstrng
it is a pan-fill dipstick, not sure if it matters but the dipstick stops short of the pan by about 5 inches, would pics help?
Old Jan 23, 2011 | 11:07 AM
jk080's Avatar
jk080
I wont know which dipstick is right for your truck. You might want to start a post like "C4 dipstick length" in the older Ford truck section, perhaps someone could just go measure one they have in there truck with a C4.
Old Jan 23, 2011 | 11:31 AM
myklstrng's Avatar
myklstrng
Alright, thx
Old Jan 23, 2011 | 08:09 PM
79_FORD_F-100's Avatar
79_FORD_F-100
My 79 f100 has a c4 the dipstick in it from tip to top of the inside of the cap is 25 3/4 inches and the full mark is 1 1/2 inches from the tip. i hope this helps. by the wy i have a tran question about mine if anyone can help. If it is cold outside about 40 or colder my trans will not pull in drive selection until it warms up for about 5 minutes. But if i put it in 1 selection it pulls fine when cold then i have to up shift to 2 then drive and its fine after that. Once the trans warm it shifts fine in drive. i was thinkin the screen is probly clogging. hoping its not the pump or converter. any help or advice will be greatly appreciated.
Old Jan 24, 2011 | 04:58 AM
Mark Kovalsky
How would the screen unclog when you put it in 1? I'm thinking the clutch seals are old, hard, and worn. Not uncommon on an old transmission. It will work in 1 because the pressure is boosted when the shifter is in 1.
Old Jan 25, 2011 | 08:03 AM
stuart1's Avatar
stuart1
5 inches short of the pan is very overfilled.
Full running level is even with or close to the pan/case junction.
