msd ignition upgrade
Old Apr 8, 2011 | 04:52 AM
  #61
lew52's Avatar
lew52
I don't think your going to be able to get though , it has to be 5-6 in thick.....Lew
Old Apr 8, 2011 | 07:52 AM
  #62
texaskid22's Avatar
texaskid22
I will put my truck on a dyno in a few months to get a baseline and then do my msd upgrade to see if there is any difference in hp. I have seen gains on small engines from the simplest things, even indexing a spark plug showed increases on the dyno. Cost effectiveness if you are prioritizing horsepower is a different story (Ignition systems usually do not give any seat of the pants difference but usually do bring in a few hp).
I prefer modifications that increase horsepower while having a positive effect on fuel economy. Headers, better flowing exhaust, better ignition, maf, wideband o2 sensors+tuned, cold air intakes, underdrive pulleys, electric fans, ect. are a few of the modifications I would refer to as a double mod, increase in hp and mpg. Most of the "double mods" do not yeild impressive horsepower improvements but all of them together on a daily driver can add a little extra punch while improving fuel economy.
My 5.8 SD EFI is identical to the OP setup and I will provide results on this topic in a few months. I'll guess a 5whp gain on ignition?
Old Apr 8, 2011 | 08:13 AM
  #63
L. Ward's Avatar
L. Ward
Ahhh.... the indexing of the plugs... haven't heard of that trick in a while (the objective is to aim the flame front towards the center of the cylinder to maximize the speed of the burn) Don't forget filing the electrode into a point too... all little tricks used to gain every last bit of power from an engine.
Old Apr 8, 2011 | 09:06 AM
  #64
lew52's Avatar
lew52
....That would be great if you could give us the dyno results , im with you , every little bit helps , i use the underdrive pulleys , e fan , air intake , msd 6al , so on , i put everything on when i built the motor , so i can't say what helped the most on my truck , but i built a couple of 5.0 stangs and can say , the exhaust was the biggest gain , its hard to tell a 5hp gain but the pulleys , e fan , ignition , mass air meter and using an aftermarket air filter was really a good jump....and a very good improvment in the way they run in general , and i guess alot of the stuff for highperformance also helps with fuel milage , but i never think about that part....Lew
Old Apr 8, 2011 | 09:21 AM
  #65
L. Ward's Avatar
L. Ward
The problem is the increased ponies makes it hard to keep your foot out of it, LOL!
Old Apr 8, 2011 | 09:23 AM
  #66
lew52's Avatar
lew52
Yeah !! thats why i never check my milage , don't want to know.....
Old Apr 8, 2011 | 12:57 PM
  #67
275CrimsonFIST's Avatar
275CrimsonFIST
Originally Posted by LARIAT 85
A Ford motorcraft coil from RockAuto is $42.79 + shipping. Your local Ford dealer should charge you around $45 - $50 for it.
For the way you use your truck, an MSD ignition nor Ford Racing plug wires are going to net you any noticeable performance gains. The Ford Racing wires are made for racing, when an engine is spinning hard. When its not doing that, you may notice that the Ford Racing wires don't work as good as the stock wires did on your mostly stock engine.
I seriously doubt that a "Superchip" did much for your truck, except make you run higher octane fuel. I don't know much about chips, but the fact is you are still running the stock restrictive heads and cam, which are going to severely limit what you truck is capable of.
All of these little "mods" you are doing *may* net you a 10 hp gain at best.
The K&N intake and NGX IX plugs do nothing in the way of performance or economy.
The headers and exhaust are a step in the right direction.
Ya, I agree that I'm going to be running genuine race car..... especially with a recreational truck I'm using for training events and range time. I'm really looking for little tweaks here and there to have a clean running truck. Headers are next on my agenda, but after that she should be a wrap. To be honest, the thing is running great with what I have on it, and has a totally different feel to it than it did without the tweaks. It has nowhere to go but up.
Old Apr 8, 2011 | 01:06 PM
  #68
275CrimsonFIST
....At this point it might be nice to know what motor and what year the truck is ?? and what you want from it performance wise....
It's a 2006 Ford F-150, XLT, 4.6L, with 40k, I bought off of an older gentleman. I bought it because of the number of times I found myself saying "I wish I had a truck" everytime I was headed to a long gun range, a training event, or doing some work to my house. Thus far, I love the thing. The little tweaks I've done have definitely changed he tune of the truck. Like I keep saying, Ford Racing headers are next, and will most likely be the final addition. Just want this thing to be a legit clean running rig.
Old Apr 8, 2011 | 01:12 PM
  #69
Nevada Al's Avatar
Nevada Al
The problem is the increased ponies makes it hard to keep your foot out of it, LOL! <!-- / message --><!-- sig -->
Ha, I hear that.. The only time I can behave enough to get an economy reading is if I'm towing something heavy.... The rest of the time I seem to prefer listening to my exhaust note instead of the radio..
This thread has got me right on the edge of buyin a box early for this engine to record the difference... Although I'm sure that would get argued to death too...lol
So who's run a Mallory box? Ward, I noticed a few times that you mentioned them as your preference.. Can you expound on that a bit... Just curious as to any differences good or bad between them or MSDs stuff..
Too bad Motorcraft don't build one..
Old Apr 8, 2011 | 01:15 PM
  #70
Nevada Al's Avatar
Nevada Al
Dude, you should be talkin to the guys in the Modular sub-forum.. This section is for the antique's
Old Apr 8, 2011 | 08:59 PM
  #71
L. Ward's Avatar
L. Ward
I have a few reasons for running the Mallory vs. the MSD.
1) The box I have (Mallory 6AL) has a built in rev limiter rather than the pills that the MSD needs.
2) The Mallory also puts out a bit more juice that the MSD (480v MSD vs. 520 Mallory).
3) The Mallory is a digital box vs the MSD being a analog box.
4) Also, when I originally built the motor, I used a Mallory distributor, so it made sense to use their box.
5) The first high performance motor I ever built was a 12:1 390 FE series, and I ended up using a Mallory dual point distributor on it, and have used Mallory parts over the years on other engines I have done and they have always worked well for me.
6) The Mallory products have been cost effective vs. the MSD line... same or less price with equal or better features.
As for running MSD components, my best friends 406 Chevy 3/4 ton that used to race in the same class I did ran all MSD components and had no issues. Personally I prefer the Mallory, but I would not turn down a MSD unit if it was given to me, and if I was in a pinch and needed a box and all that was available was a MSD, I would run it with no worries about it.
Old May 4, 2011 | 05:15 PM
  #72
Lumpy87's Avatar
Lumpy87
Not to add to the debate but when I first added an MSD 6A, along with a Blaster coil, I had all sorts of issues with idle and missing so I unplugged the 6A until some time after I upgraded to a FR MAF conversion. I forgot the MSD was still sitting there under the hood.
While the MAF made my truck run a lot nicer (slight MPG but no real HP gain), after I reconnected the 6A there was a noticeable improvement especially in the lower end. I am a true believer when it comes to Motorcraft plugs. Actually more of a disbeliever in gimmick plugs. Especially after an epic fail with Bosch plugs. Lucky they didn't ruin my motor.
I'm told if you really want to see some good gains you should get their ignition kit that also comes with their distributor. I could have just been getting a sales pitch though.
Old May 5, 2011 | 09:39 AM
  #73
73FOMO's Avatar
73FOMO
The newest MSD 6al is digital, puts out more energy among other improvements...such as rotary dial rpm limits.
MSD Part # 6425.
With Soft Touch Rev Control
Higher output with 530 primary volts and 135mJ of spark energy
Efficient components use less current to produce more power
Set an rpm limit on the 6AL with two rotary dials
Same bolt pattern as the original 6AL with a lower profile housing
Built-in LED for system checks
All wires exit the same side through a locked, sealed connector
sand1
Sep 4, 2016 07:24 PM
ilovemy60ford
Sep 14, 2011 07:29 PM
Khauler
13
Jan 31, 2011 10:28 PM
410F-100
Dec 4, 2010 09:08 PM
Justin460
17
Feb 15, 2007 01:29 PM
