6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tow/Haul button not working?
Old Jan 20, 2011 | 07:43 AM
fordff's Avatar
fordff
Hey all,
I have a new to me 08 SD, and the only thing I can find wrong with it is that the Tow/Haul switch doesnt work. According to the manual, it is tied into the same fuse that the backup alarm uses, and it works fine.
Has this happened to anyone, and is there a quick check or fix?
I have never had a Ford AT, so I am completely in the dark with this.
Thanks,
Digger
Old Jan 20, 2011 | 07:56 AM
va450's Avatar
va450
My 08 250 would allow me to turn tow/haul on anytime, but my 450 will only turn on or off if the truck is stopped and in park. Sometimes there may be a fuse that activates a relay in the underhood fuse box in addition to a regular fuse. This fuse may be labeled tow/haul relay or maybe something else to do with towing relay. I had an 07 that when the power windows stopped working the fuse that was the culprit was labeled instrument cluster. Go figure.
Old Jan 20, 2011 | 07:57 AM
fg250's Avatar
fg250
does the light come on in the dash? quick check is if you are going along at 55-60, put it in tow/haul mode and get on the brake, as you slow down you should feel and hear it downshifting, if not, then it definately isn't working.
Old Jan 20, 2011 | 09:04 AM
jshumadine's Avatar
jshumadine
I had it happen early with my 2008 diesel. It would work when I pulled the shifter towards me while pushing the button. They replaced they entire shift unit and it now works fine. It was done under warranty.
Old Jan 20, 2011 | 09:55 AM
sdetweil's Avatar
sdetweil
My 08 had the same problem.. turned out one of the wires from the button was broken.
I pulled the stalk and repaired it myself..(added another wire)
heres how https://www.ford-trucks.com/forums/8...ml#post7944539
Sam
Old Jan 20, 2011 | 12:26 PM
fordff's Avatar
fordff
Very cool fellas. I will check on it tomorrow, I have not tried it by pulling the lever to me, but the loose/frayed wire does make sense.
Thanks for the info, will update ya.
Old Jan 21, 2011 | 08:03 AM
sdetweil's Avatar
sdetweil
key here for me was to NOT try to change the wire connection ON the button or the connector to the harness.. but in between. (all but the last inch on either side.
Sam
frassettor
Mar 12, 2023 03:13 PM
KW7DSP
Oct 10, 2015 01:58 PM
gernest2
Sep 17, 2011 01:14 PM
Nathan
Dec 2, 2010 04:53 PM
sdetweil
Sep 17, 2009 06:57 PM
