Trans Problems- Codes n flashing lights
Old Jun 16, 2012 | 05:21 PM
saddleupthepalomino's Avatar
saddleupthepalomino
Okay, had a similar issue the other day. Had the 04 Excursion overheat due to small pinhole (read: only leaked when hot) in degas bottle. Replaced degas bottle, and then the one day later, was almost to work when "tow/haul" light flashed and truck would not move forward off the exit ramp... Code reader showed PO730. Had it towed home, next day checked and trans. seemed low on fluid by approx. 1.5 qts. (it never has shown a leak, and fluid looks clean, does not smell burnt). Checked cold, so added fluid 1 pt at a time, now warmed up it shows mid-mark in the "hot" area. Erased code, and code hasn't returned, nor has tow/haul light flashing recurred; but once warm it seems... trans does not want to "pull". Any ideas, help, or answers would be much appreciated.
aaronbrace
Feb 3, 2023 10:18 AM
felix4
Sep 4, 2016 07:23 AM
Nathan
Dec 2, 2010 04:53 PM
timsfordtruck
Jul 21, 2009 03:43 AM
03KingRanchF250
Mar 31, 2007 01:25 PM
