Baro sensor reading low, why?
Old Jun 16, 2012 | 01:28 PM
davelong667's Avatar
davelong667
Awhile back I posted about my turbo puffing and what not... A turbo removal and cleaning solved that, my unison ring was jammed up with soot. Turbo is flawless now. However, i still have the low baro reading code. I replaced map sensor and it reads 97 kpa koeo. Which is pretty much where it should be, my other cars all read 96-97 kpa koeo, and now so does my f250. Sooo.... My baro should also read 97kpa, or close to it. But it reads 81. I replaced the baro with a brand new fomoco oem part, still... 81. This is wayyy to low. When i unplug the baro sensor the pcm defaults to 98 kpa. only when baro is connected back up does it drop on back down to 81
Now to the core of the question. When a guy uses a tuner "sct, edge" and so on, will they manipulate baro readins and such for more power? If so.... Could it be that the prior owner left a tune on the truck when he got rid of it. Orrrr...
Do you guys think i might have a wiring or pcm problem?
I tested the connector to the baro, pin 2 has 4.99 volts koeo, both to ground, and to pin 1. Seems good to me.. I dunno
Old Jun 16, 2012 | 01:34 PM
BLADE35's Avatar
BLADE35
A tunner wont change BARO reading AFAIK
BARO sensor sets the Baseline Reading for ALL Pressure sensors
So if you think the reading is OFF you need to Check the V-Ref 5Volts referance signal to it
since sensor is new time to check other possibilities
Do you have a DVM and or a ScanGaugeII?????????????????????
DUH you checked Vref already
What is the Exact DTC you get????????????????????
Old Jun 16, 2012 | 01:42 PM
davelong667
My wife has truck right now and i will get codes when she gets back.
There were 2 of them.
One i know is P006a something about map and air flow correlation.
And the other says low reading bar sensor.
Im thinking this baro problem is goofing up the other readings, like you said, that it sets the baseline for the other sensors.
Old Jun 16, 2012 | 01:58 PM
BLADE35's Avatar
BLADE35
Check BARO & MAP & EBP at KOEO need to be within 0.5psi at this time
What gauge do you have?????will it get these sensors???^^^^
Old Jun 16, 2012 | 02:07 PM
davelong667
Using Snap-On Solus Pro for diagnostic.
It does not show ebp sensor, just map and baro out of the 3.
I think my pcm was flashed to delete the use of the ebp.
The 6oe17 update or whatever its called.
So it cant see ebp.
Hopefully i can find whats causing the map and baro to not match.
Old Jun 16, 2012 | 02:09 PM
BLADE35's Avatar
BLADE35
what year is the truck?????
03????6.0L????
Old Jun 16, 2012 | 02:14 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Looks like an 03 Benny.
Old Jun 16, 2012 | 02:30 PM
BLADE35's Avatar
BLADE35
Thats what Im thinking too
So that points to MAP sensor corralation whats MAP reading at KOEO?????
Old Jun 16, 2012 | 02:35 PM
davelong667
Its an 03 f250. Which gives it the addicting turbo whistle. Kinda loud but I love it.
The map at koeo is 97kpa.
I dont know if it matters or not, but the cat converter has been deleted by prior owner and a straight pipe is in its place. Nice job actually, nice welds on it.
Old Jun 16, 2012 | 02:52 PM
BLADE35's Avatar
BLADE35
Well FORD Spec for BARO is 96.5kpa and same for MAP at KOEO
Im thinking the BARO wire harness is chaffe or a plug not fulley seated
with Both Old/New Baro sensor reading the Same odds are the Baro sensor is OK and wireing issue plug issue and slim chance bad PCM but PCM are good and dont fail very often at ALL
When you get the truck Back check MAP & BARO readings again at
KOEO=report value
Low Idel=report value
High Idel (2500rpm)=report value
I do have a feeling these will be good but verify and its going to be a wire problem to Baro
Going to need to Check continuity for BARO Wires to PCM Might even need to Load Testt Baro wire Harness cuz it can check Good for continuity but Fail with Voltage Load
Here is a Link to PCM Plug Pinout so you can see what Pins need checked
PCM PLUG PINOUT
http://api.viglink.com/api/click?for...13382481502533
Old Jun 16, 2012 | 08:17 PM
davelong667
Ok thanks blade, i will run some wiring tests soon and see what i find. Those diagrams will lead me where I need to go. I appreciate it.
W7PSK
6.7L Power Stroke Diesel
Jan 28, 2016 11:41 AM
orphius
Jun 4, 2012 12:53 PM
triskit16
Oct 27, 2008 09:59 PM
BlueOvalHead
Jan 21, 2008 02:32 PM
Knotwild
17
Oct 23, 2007 07:52 PM
