Pretty sure it will bro, the bolt pattern is the same on all 1356's so i would venture a guess that the extension off of the 5sp is the same bolt pattern for the transfer case. do you have the 1345 now?
The transfer case i'm looking at is listed as stamped:
13-45-065-901
I'm a little concerned that the output shaft for the rear drive shaft won't work. Mine currently has an extended output shaft that bolts to the case, this one seems to end in just a short shaft.
Id get a 1356 with the PTO, but thats just me. Ensure the shafts are the same or you will be buying and replacing parts, i am sure you can find the right one for the same price, i found a cherry one for 50 bucks.
