Changing transfer case lube E4OD
Old May 31, 2010 | 06:50 AM
Marauder2004's Avatar
Marauder2004
I am planning to change the fluid and filter in my E4OD today and was wondering if the transfer case lube is intermixed with the tranny fluid? And is there a separate drain for the transfer case?
Answers appreciated! Thanks folks.
The truck in a '92 F-250 4x4.
Old May 31, 2010 | 06:56 AM
littlehusky's Avatar
littlehusky
They are separate.
Both take same fluid though.
If you're doing both buy a 5 gallon pail. E4OD takes a lot of fluid ~15 quarts or so, Tcase takes 2 or 3 IIRC.
Trans you drop the pan, unless someone installed a drain plug. (good idea to do that when you got it off)
There is a drain plug is on the TCase. there should be 2 square drive plugs.. one drain, one fill. They take either 3/8 or 1/2" socket extention. Make sure you use the extension, not just a ratchet, and be careful, the plug WILL strip.
Old May 31, 2010 | 07:34 AM
Lazy K's Avatar
Lazy K
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Here is a good writeup on doing the E4OD. And what LH says for the transfer case.
Salts
May 7, 2014 10:50 AM
Andy Sullivan
Feb 15, 2014 04:52 PM
Hamberger
Jun 1, 2006 11:12 AM
stepside64
Offroad & 4x4
Mar 6, 2004 12:40 AM
kev100
Mar 13, 2003 07:13 PM
