Broken Transfer case lever
Old Oct 2, 2006 | 11:48 AM
kiohio1985's Avatar
kiohio1985
Broke where it hooks down at the transfer case.
Lever runs to this piece then this piece hooks to the Transfer case.
Does anyone make one of these that is a little heavier duty.
Seemed to break awful easy.
Of course it could have been stressed before I got it.
If not is Ford my only option?
It is on a 97 F350 with 460 and E4OD.
Thanks, KO
Old Oct 2, 2006 | 07:13 PM
kiohio1985's Avatar
kiohio1985
Anybody got any idears??
KO
Old Oct 3, 2006 | 02:24 PM
gustang818's Avatar
gustang818
Weld it and fishplate it?
Old Oct 3, 2006 | 06:38 PM
kiohio1985's Avatar
kiohio1985
It's Cast Aluminum
Ho Hum....
I like Steel LOL
KO
Old Oct 4, 2006 | 09:20 AM
gustang818's Avatar
gustang818
You're talking about that aluminum piece at the bottom of the shifter that is bolted onto the transmission? I broke mine trying to get the rod off that goes to the transfer case. I had it TIG welded locally for $20. The guy did a great job and I don't think it will break there again. I also put grease zerks in it to lube it so it doesn't seize up again.
Old Oct 4, 2006 | 09:32 AM
kiohio1985's Avatar
kiohio1985
COOL
I'll try that!
Thanks alot!!
KO
Old Oct 4, 2006 | 09:51 AM
gustang818's Avatar
gustang818
Just take it all apart to the bare housing before you have it welded. There are plastic parts inside the housing that will melt if you don't. It's not that hard to do.
93idis
Sep 16, 2012 02:20 PM
Krisx125
Mar 11, 2012 09:01 PM
KawiRider78
May 12, 2011 02:12 AM
deisele75
Oct 5, 2005 03:58 PM
murphy
Sep 10, 2005 03:42 PM
