Sponsored by: Real Truck
Rear Differential
Old Jan 19, 2011 | 08:01 AM
spstgermain's Avatar
spstgermain
Rear Differential
Getting ready to do rear differential fluid and transfer case fluid changeout.
1 Can anyone tell me how I can tell if I have Limited Slip or not from the sticker on the truck. Need to know for the limited slip additive.
2 What fluid do you recommend for this??
Thanks for your help!!!
Old Jan 19, 2011 | 09:39 AM
cmalinowski's Avatar
cmalinowski
I used this
There is probably another one on this site, maybe in the tech docs, but I am not feeling well and don't feel like searching.
EDIT: use the tech folder version. It's much better. Apparently I felt like searching
Chris
Old Jan 19, 2011 | 09:42 AM
cartmanea's Avatar
cartmanea
Use a good synthetic 75w-140, like Amsoil Severe Gear or Mobil 1, and you won't need any LS additive.
Old Jan 19, 2011 | 10:59 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I used Mobil 1, and I sure DID need an LS additive with it - it chattered like a spider monkey.
Old Jan 19, 2011 | 11:21 AM
redford's Avatar
redford
What is the axle code on your door sticker? If the code has an L or sometimes an N it is limited slip.
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
Old Jan 19, 2011 | 12:41 PM
mikesmayhem's Avatar
mikesmayhem
I used the AMSOIL. Did not need the additive and the LS works fine. (or at least as well as the Ford LS can work).
Old Jan 19, 2011 | 04:36 PM
SuperDutyScaler's Avatar
SuperDutyScaler
75w 140 mobil one, and i didnt add ls additive. works ok no chatter at all. and i used mobil 1 atf fluid when i did my transfer case. its crazy how dirty it was at 70k!
Old Jan 20, 2011 | 05:03 PM
mwsF250's Avatar
mwsF250
I used Redline 75w140, and did not need any additive.
Redline actually recommended I fill without any additive and trying it. If chatter, then add in small quantities (ounce or two at a time) until chatter goes away.
Texas Bob
Oct 19, 2019 12:12 AM
Platinum08
Dec 10, 2014 09:39 AM
dgruhlke
May 1, 2012 11:22 AM
mia
Apr 10, 2007 08:52 AM
Pastmaster
May 17, 2002 09:42 PM
