Can you get replacement steering shaft colars ? I talking about the white piece at the lower end of the steering column, it can be seen in the engine compartment. It's a '79 4x4 application. Don't see any in catalogs, only 2wd pieces. Thanks !!!
I think this is what you're looking for. Bottom of the page # 19. Doesn't say if it's 2 or 4WD (2WD/4WD same). LMC Truck Parts - Page 49
#19 is the bearing only. LMC doesn't list the bearing retainer (OP: 'colar'). Y'all specify a colar, you'll get a shift collar used for A/T or a 3 speed M/T.
