drop pitman arm
Old Jan 17, 2011 | 08:56 PM
whack&stack's Avatar
whack&stack
drop pitman arm
need to buy a drop pitman arm to fit 4-6 inches of lift anybody got one they want to sell? needs to fit a obs 97 f250
Old Jan 17, 2011 | 09:47 PM
Talyn's Avatar
Talyn
Shoulda came with your lift kit.
Old Jan 17, 2011 | 10:10 PM
jg96powerstroker's Avatar
jg96powerstroker
dude you wanna sky jacker drop, they are made better, i had a rough county lift and the pittman broke 2 times!! sky jacker is thicker and better
Old Jan 17, 2011 | 10:57 PM
whack&stack
i didnt order a kit or i would have one thats why i need to buy one seperatly. i only had 3 inches on it and didnt need a drop pitman arm but i am going up to 4" with lift springs and need the pitman arm now.
Old Jan 17, 2011 | 11:49 PM
Talyn's Avatar
Talyn
Seeing as you have a 250, did you get the center bracket drops?
or are you just using the spring lift on the outside?
If you dont have the TTB pivot drops, dont even put the lift on till you get them.
As to where to get the pitman arm, not sure.
Old Jan 17, 2011 | 11:57 PM
BadDogPSD's Avatar
BadDogPSD
Summit Racing sells them
Old Jan 18, 2011 | 12:06 AM
jg96powerstroker
x2 with talyn, if you need pivoit i may have a set for a 4in lift and will look may have 4 in pit man. when you do the lift its a good idea to do a fitted leaf in front as well to help with weight of are 7.3
Old Jan 18, 2011 | 09:19 PM
whack&stack
i have already installed the drop pivots i did that when i did the 3 inch lift they have camber nuts on them so you can adjust them from 2-4" of lift cause i knew i wanted to go to 4" springs one day. part of the 3 inch lift is a add-a-leave and i will be throwing that into the lift springs as well to help deal with the weight. i hope you have one you can make me a deal on. dont really wanna pay retail plus their outrageous shipping cost.
Hyperactive460
WTB - Parts & other
Nov 21, 2015 06:33 PM
Ford_Six
Feb 12, 2012 12:29 AM
bmacky14
Jun 22, 2009 08:41 AM
Weldmen
Aug 6, 2006 11:06 PM
JFR3
May 5, 2003 08:06 AM
