E4OD jumping between 3-4
Old Jan 17, 2011 | 06:42 AM
b4hntn's Avatar
b4hntn
Have I missed anything before taking it to a shop?
1994 E4OD got the factory warranty upgrade the first year.
After transmission warm up the shifting is erratic. Shift from 1 straight to 4. Around 50mph in OD it only goes into 4 with light throttle but will not hold 4 more than a couple of seconds then back to 3. If I use very heavy throttle while it is in 4 it will hold it to 75 but when I let off it shutters then slams between 3-4.
At 170K miles replaced the filter and drained the TC. Filled with Mercron.
Then at 19OK and 65mph it suddenly slammed into 3 then back to 4 every few seconds. Only code was 622 KOEO circuit fault #2 shift solenoid.
Since then I have replaced the solenoid pack twice, VSS, MPLS cleaned all the battery cable connections. I even got the transmission wiring harness on the table and every pin tests perfect. Wiggle tested the #2 wire. Could not find Mercron on the solenoid pack replacements so went with the D??/Merc. Continue to get only code 622 after clearing them. Found pan was shiney and clean when solenoid pack was replaced and the transmission had worked perfectly until now.
So have I done every thing possible before going to a shop?
What does it sound like to you ?
f100guy
62
Feb 2, 2026 04:15 PM
flyboyd8
Apr 18, 2023 06:50 PM
jlarr
Jan 4, 2015 09:47 PM
danieib
Sep 1, 2013 12:20 PM
eg1031
Aug 19, 2013 08:55 PM
