Neutral Safety/ Backup light switch ?
Old Mar 7, 2003 | 04:31 PM
popman's Avatar
popman
Question Neutral Safety/ Backup light switch ?
i was told at the mechanic shop i need a safety or backup light switch for my lights to start working again..he said it was on the automatic transmisson i have a [C6] ..now what would this switch look like because in my *** book it shows one ..but the mechanic saying to go to a ford dealership to buy it..i have a 1977 ford truck..thank you...
Old Mar 7, 2003 | 06:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
If you want a good one you will need to go to Ford.
Old Mar 7, 2003 | 06:43 PM
Mil1ion's Avatar
Mil1ion
I don't know if a dealership still has them or not!
here's what it looks like though.
Old Mar 7, 2003 | 07:51 PM
mudder trucker's Avatar
mudder trucker
i thought they were on the steering colume on the 77 trucks. mudder trucker.
Old Mar 7, 2003 | 08:24 PM
Mil1ion's Avatar
Mil1ion
I thought they were on the Steering Column in a 77 as well?
Maybe it is a late 77?
Old Mar 7, 2003 | 08:41 PM
theonlybull's Avatar
theonlybull
our 77 has the switch on the colum.... i thought only 78 up were on the tranny...
if it's just the lights, you can put a switch on them.
Old Mar 7, 2003 | 09:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Remember the 77-1/2 split. If the switch is on the tranny it was used for many years and may still be Ford stock.
Old Mar 8, 2003 | 08:49 PM
popman's Avatar
popman
Unhappy Neutral Safety/ Backup light switch ?
77 ford..well today i went and look under around the my transmisson and cannot find the switch the mechanic said that was there..somebody said it was on the steering column now i have not looked there what would it look like?..now the C6 that is in it was put in before i owned it..but till a year ago the reverse lights was working i even checked the bulbs and wires going to it..
Old Mar 8, 2003 | 09:14 PM
theonlybull
the colum mounted switch should be under the dash, on the top side of the colum. i think the colums with that switch are very thin, about 2" tube, but the 78-79 colums are closer to 4" around, and covered by a plastic tube from the shift ring to the dash...
Old Mar 8, 2003 | 09:41 PM
popman's Avatar
popman
Smile Neutral Safety/ Backup light switch ?
well i found the switch it was on the column like yall said..not on the transmisson like my ASE mechanic said..lol..then i got on autozone website and found the part there 28 bucks so i guess that is good enough..hopefully that is what is wrong with it..thanks again
Old Mar 8, 2003 | 11:09 PM
broncoman85's Avatar
broncoman85
It'll be on the shift column, on top right behind the firewall. Later Whit
Old Mar 9, 2003 | 12:16 AM
macguyver's Avatar
macguyver
Also be careful of the actuator tang. It's just thin stamped steel bolted to the shift tube (I think) and can get bent.
Old Mar 9, 2003 | 10:34 PM
Thudpucker's Avatar
Thudpucker
Cool Neutral Safety/ Backup light switch ?
before I'd buy a new switch, I'd look to see what the problem with the backup light circuit actually is?
I remember having a time with a switch like that on my '56' Ford sedan. But replacing the switch didn't fix it, and the parts store wouldn't take the switch back.
Old Aug 8, 2003 | 10:44 PM
robbowhunter's Avatar
robbowhunter
where is the backup light switch on a 1977 ford f150 c6 tranny big block located at? everything works but backup lights .
Old Aug 8, 2003 | 10:48 PM
Mil1ion's Avatar
Mil1ion
Which engine again ?
The 351M/400 are small blocks & the 460 is a big block but they share the same bolt pattern for the bellhousing.
Same place !
66F250CS
Apr 5, 2014 01:43 PM
Dskeet6
Sep 14, 2010 10:29 PM
Justntimeracing
23
Apr 17, 2008 11:21 PM
albcasummit
Electrical Systems/Wiring
Nov 8, 2005 12:17 AM
salty4568
Jan 22, 2004 07:42 PM
