map sensor relocation for intercooler?
Old Jan 14, 2011 | 02:52 PM
jchosler's Avatar
jchosler
What is the process to relocate the map sensor when an intercooler is installed?
I know it needs to be moved to the hot side but How do you mount it if youre not using the 99+ spyder?
I modified the original y-pipe
Old Jan 14, 2011 | 03:56 PM
427 fordman's Avatar
427 fordman
I'd just drill and tap a fitting in the hot side of your modded ypipe.
Old Jan 14, 2011 | 06:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
X2.
I did it in my early 99 spyder.
Old Jan 15, 2011 | 09:29 AM
tbone heller's Avatar
tbone heller
Why do you put it on the "hot side"? The instructions from Banks has it on the "cold side". I would think that the engineers at Banks have done some research of where it works best. Just wondering the reason for relocating it.
Old Jan 15, 2011 | 10:24 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Thats a good question, but dont believe all you read, Banks also say that the EGT probe should be intalled in the down pipe and its a way BETTER in the exhaust manifold.
One reason I have read is that in the hot side you have less turbo lag.
Old Jan 15, 2011 | 01:41 PM
tjbeggs's Avatar
tjbeggs
You would think that Fale Banks and his engineers knew something guessing from the amount of money they charge for their inferior products but on these trucks Fale Banks is an idiot!
Putting the Map sensor line on the hot after installing an intercooler lets the PCM "see" the boost faster therefore it fuels harder and faster. If you have an intercooler swap it once and you will see what we are talking about. It is a noticeable difference and if you have the Banks Set up its easy as putting a thread barb fitting in the turbo outlet and running your hose.
Old Jan 15, 2011 | 01:58 PM
Robbgt's Avatar
Robbgt
LOL @ banks and his engineers. He could give 2 ***** about PSD's
That white shirt is way to clean for him to be doing any real work in the shop
Old Jan 15, 2011 | 06:14 PM
jchosler's Avatar
jchosler
Thats what I was told as well. I have a lot more turbolag than prior to the IC install and I hope to get rid of some of that by relocating the sensor
Old Jan 16, 2011 | 05:32 AM
tjbeggs's Avatar
tjbeggs
Yes it will decrease turbo lag as well.
Tyler.172
Oct 30, 2015 04:25 PM
Skipper 7886
Mar 2, 2015 09:46 PM
91 Dually
20
May 21, 2014 08:44 AM
Chalkie
6.4L Power Stroke Diesel
Dec 22, 2013 08:42 PM
Jnowaczyk
Modular V10 (6.8l)
Nov 5, 2013 02:55 AM
