Map Sensor hookup location after intercooler install
Old May 16, 2014 | 05:57 PM
91 Dually's Avatar
91 Dually
I recently installed a 7.3 intercooler on my 97... I left the hose to the map sensor in the stock intake plenum location. I read someone today said it should go in the hot side instead when intercooled.. Any thoughts on this? Does it make a difference? (I also have the line for my boost gauge Teed into this hose)
Old May 16, 2014 | 06:50 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
I have read that youll have less turbo lag and you wont loose 2 psi boost. I left the boost in the hose between the hot side and MAP sensor.
Old May 16, 2014 | 11:27 PM
oldbird1965's Avatar
oldbird1965
That's what I did, hot side.
Old May 17, 2014 | 07:55 AM
Pikachu's Avatar
Pikachu
For what it's worth, the MAP line is on the cold side in the Super Duty trucks. I'd think the PCM would need to adjust fuel and timing curves based on the pressure at the manifold rather than the pressure at the turbocharger compressor outlet.
Old May 17, 2014 | 09:09 AM
oldbird1965
The OBS PCM doesn't 'learn' like the SD's.
Old May 17, 2014 | 11:18 AM
Pikachu's Avatar
Pikachu
The SD PCM doesn't learn either.
Old May 17, 2014 | 11:33 AM
91 Dually's Avatar
91 Dually
well, It seems like it would show a slightly higher boost in the hot side. Just not sure how, if at all, that would effect the way it runs
Old May 17, 2014 | 08:21 PM
ReBilld's Avatar
ReBilld
If you have it in the hot side and it sees more pressure, the pcm should give it a little more fuel making more power.
Old May 19, 2014 | 01:41 AM
Pest007's Avatar
Pest007
night and day difference between the hot side and plentum side... Much less lag when on the hotside
Old May 19, 2014 | 10:59 AM
tjbeggs's Avatar
tjbeggs
As said there will be less turbo lag if you place on the hotside- I have run both sides and there is a noticeable difference when its reading off the hotside
Old May 19, 2014 | 11:11 AM
Pikachu's Avatar
Pikachu
I'm can see where there would be less lag, but how does it affect the defueling strategy at the top end (if the OBS PCM has a defueling strategy for for overboost like the SDs)? Seems like it would defuel sooner since you'd be seeing a higher pressure at the hot side, unless you've installed a boost fooler. There may be advantages to and disadvantages to each side.
Old May 19, 2014 | 11:30 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
WOW! TJ is alive!. Glad to see you here Tim.
Best regards.
Old May 19, 2014 | 01:16 PM
tjbeggs's Avatar
tjbeggs
No defuel on the OBS- A select few (mine) can overboost the MAP and get a messed up signal that feels like a defuel- in that case a simple min regulator in the MAP line solves the problem.
Jose, I am alive and well! Good to hear from you!
Old May 19, 2014 | 09:46 PM
91 Dually's Avatar
91 Dually
ok, thanks for the responses guys. I guess I will have to switch to the hot side now and give it a try.
Old May 20, 2014 | 09:41 AM
BIGRED 7.3L's Avatar
BIGRED 7.3L
Could one of you who have moved it to the hot side provide a picture of where and how you did it? I am gathering the parts but this is the first I have read of moving the map to hot side.
