e4od
Old Jan 14, 2011 | 02:39 PM
gumper 123's Avatar
gumper 123
e4od
Has any body had to replace pcm for there tranny? I put one in 8 months ago and it is acting just like it did so frustrated i could limp it to scrap yard and watch them crush it.
Old Jan 14, 2011 | 03:06 PM
ManicMike's Avatar
ManicMike
Are you sure the years are correct between the shift solenoid pack and TCM? If it's the wrong years, you'll fry the TCM.
Old Jan 14, 2011 | 05:13 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
do you have a code reader gumper?
http://www.oilburners.net/wiki/tiki-...hp?articleId=9
Old Jan 14, 2011 | 05:53 PM
gumper 123's Avatar
gumper 123
I had my trans. rebuilt in febuary replaced solonoid pack then. all the parts were bought from a well known place around here. later had problem with od light coming on very dim and no tach after checking all plugs 5 times replaced brain problem solved. today was pulling out of drive way noticed it was definately not starting in first dim od no tach. I have new tach sensor mlps,flips,on and on. i taped on brain today bang every thing worked later quit again thats what it did before cleaned plug for brain with dieelectric cleaner and greased with die electric grease. still comes and goes. That is what it did before. No i am not positive that tcm and solinoid pack match. just depending on trans parts guy and ford dealer on both of them. yes i can get a codes reader will get one in morning.
Old Jan 14, 2011 | 07:59 PM
rodneywar's Avatar
rodneywar
did you relplace the tcu relay? might be a problem
Old Jan 14, 2011 | 08:07 PM
FORDF250HDXLT
do you still have this problem?
https://www.ford-trucks.com/forums/9...h-problem.html
https://www.ford-trucks.com/forums/9...nsmission.html
https://www.ford-trucks.com/forums/9...l-no-tach.html
did you inspect the wiring?
Originally Posted by Dave Sponaugle
The most common inducation of a problem is bare wires where they enter the sensor.
The insulation shrinks back from the heat and oil, then water gets inside to the coils and starts corrosion.
you really,really do not want to be driving the truck while the OD light is flashing.that's really to get you home,driving nice and easy to fix it.
it could be much cheaper for you to have a shop repair whats wrong now,rather than keeping driving it all this time,and need to replace the trans latter.
it can shift really,really harsh etc.not good for the trans.
the E40D gets such a bad rep,because this is just what many people do.keep driving them when like this,and when the trans goes out,they blame it on the trans.
just be careful and try to fix this before you hurt your trans.i don't mean to give ya a hard time.i just don't wanna see ya loose a trans needlessly,like so many E40D owners have.
Old Jan 14, 2011 | 09:02 PM
gumper 123's Avatar
gumper 123
Yes i do have the same problem but it went away 8 months ago when i changed pcm. It act just as it did before. I havent checked the wiing today but when it did this before i peeled the protector away and checked every strand and nothing out of ordinary.
Old Jan 14, 2011 | 09:09 PM
FORDF250HDXLT
all fuses are good? brakes lights work?
i had my dome lite/door jam switch go bad,so i pulled the fuse to it....mistake.the trans shifted very late and hard! and then the OD light came on.i quickly turned around and parked the truck.i thought back at what was changed and remembered doing that the night before.
put that fuse back in,and pulled the bad door jam switch instead.
everything was perfect and off i went.
funny how some stupid things like that got tied into the operation of the trans.not very smart on fords part for keeping that stuff on devoted fuses apart from the required pcm signals.
since learning that,i made sure to keep a variety pack of fuses in the glove box.
i should snip the line to the dome light myself and install a fuse holder as i discover each of fords mistakes.
Old Jan 14, 2011 | 10:09 PM
BlueOvalBud's Avatar
BlueOvalBud
Fords biggest mistakes include anything electronic
I can't believe there are so many things that effect the operation of the E4OD. A dome light!?
You and your e-pump and e-fan and e-trans! (Just kidding with ya!)
Old Jan 14, 2011 | 11:10 PM
FORDF250HDXLT
lol.electric is nothing to be afraid of.
well not the dome light,but yes it's same fuse.not very smart on fords parts with that one.
Old Jan 15, 2011 | 09:39 AM
gumper 123's Avatar
gumper 123
Took the boys rabbit hunting eary drove about 20 mile never acted up. however i did forget to tell that yesterday before it acted up i wired up my meyer snow plow lights. but they all hook up to head lights side marker and turnsignals dont see how that would cause problem. Does the trans realy run any of thaT STUFF?
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Worktrucks
15
Feb 2, 2013 11:02 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
beartracks
Oct 18, 2002 02:20 PM
