Airbag code 42 front sensor location 2005 Aviator
Old Jan 13, 2011 | 08:24 PM
naturalscience42's Avatar
naturalscience42
So I found out code 42 on the airbag code is front sensor # 2. Anyone know the location of this sensor and how to get at it? Do I need to disconnect the battery before unplugging the sensor? I want to try cleaning off the connections, and will see if that will do the trick. Thanks
Old Jan 14, 2011 | 07:11 PM
ncranchero's Avatar
ncranchero
It is always recommended to disconnect the battery before servicing any part of the SRS. Check the connector, the mounting surface of the sensor for rust and the sensor itself for being loose on it's mounting bracket.
LFC 42 = Restraint System — Impact Sensor Fault (Front Impact Severity Sensor Circuit Fault)
Old Jan 14, 2011 | 07:34 PM
naturalscience42
Thank you, I will start looking. Had the front cowel off and couldn't find it. I will now try again. Another issue. Do you know why my mirrors don't tilt when I go in reverse? The backup sensors don't work either. Are these two things tied together?
medic8852
2004 - 2008 F150
Oct 2, 2021 12:21 PM
pdrhodes1
1983 - 2012 Ranger & B-Series
13
Jun 8, 2016 03:22 PM
rockrawlingjeep
2004 - 2008 F150
Sep 26, 2014 11:04 PM
jroehl
May 25, 2012 06:15 PM
fordinsky
May 23, 2005 02:51 PM
