Injector cleaning - how do I know when time ?
Old 05-10-2014, 06:33 AM
JRS2's Avatar
JRS2
JRS2 is offline
Basically re read that technical info, never done it on this truck and have a couple other vehicles that may need it, but how do you know it is time ? Also, what kits recommended by manufacturer ? 5.0 plus a pontiac and a caddy may be on this to do list ....
Old 05-10-2014, 08:21 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
I assume you are talking about a hook up to a machine type cleaning?
Never done that ($$$)
I just run one of the best injector cleaners yearly, redline SL-1. And its a tenth the price of a machine cleaning.
Old 05-11-2014, 09:06 PM
JRS2's Avatar
JRS2
JRS2 is offline
Bad Leroy:
No, if you read the sticky message and go down to the thread of how to clean them on the bench that was what I was referring to. My question is how does one know it is time, maybe a driveability seat of the pants, or perhaps the codes tell you ?
Old 05-11-2014, 09:38 PM
Puddy's Avatar
Puddy
Puddy is offline
What colour are your plugs? Too white, leaning out. Too dark, running rich. Also voltage can have an effect or it aswell. So keep in mind that you should have consistent voltage across all injectors.
Old 05-12-2014, 01:49 PM
andym's Avatar
andym
andym is offline
When I cleaned mine a few years ago, the truck ran noticeably better. Idle and power were both much smoother. Of course, I also cleaned the intake and replaced the gaskets, so I could have plugged a vacuum leak or make the incoming airflow smoother.
It never set any codes or anything else, so I don't know that you're going to get an answer to your question.
BroncoBilt
1978 - 1996 Big Bronco
01-02-2015 10:53 PM
d-day
05-08-2014 09:25 PM
brickie
02-21-2008 12:36 AM
MemOrex
15
11-28-2005 07:05 AM
mzimmers
08-17-2003 01:57 AM
Quick Reply: Injector cleaning - how do I know when time ?
