Injector pintle cleaning?
Old Feb 19, 2008 | 07:12 AM
brickie's Avatar
brickie
Should I clean them up before I put them back in ? If so what should I use ?TIA
Old Feb 19, 2008 | 05:34 PM
npccpartsman's Avatar
npccpartsman
I guess I don't know what you're refering to when you say pintle. I would keep the injectors themselves as clean and oiled as possible. If you're refering to the hold downs then yes clean them. Other than that I'm lost
Old Feb 19, 2008 | 06:24 PM
3000 FPS's Avatar
3000 FPS
Do they have carbon on them? One thing I have read is to stick a vacume pump on the end where the pintle is and draw vacume on the injector to see if it will hold vacume. From what I have read they should and if they do not then they could be bad.
Old Feb 19, 2008 | 06:31 PM
3000 FPS's Avatar
3000 FPS
The Pintle is the nozzle needle at the end of the injector.
Old Feb 19, 2008 | 09:10 PM
npccpartsman
I guess pintle equals plunger? that is the piston that injects the fuel through the nozzle? Other than that there really isn't a nozzle needle to speak of in this injector, at least not like the old bosch mechanial injectors used in tractors.
Old Feb 20, 2008 | 09:40 AM
brickie's Avatar
brickie
The 6.0 bible has the breakdown on the injector.Pintle would be the same as nozzle in my minds eye.I was wondering if it is a normal procedure to clean the carbon off the tip before I put them back in. Judging from this post they are going straight in.
Old Feb 20, 2008 | 10:24 AM
3000 FPS's Avatar
3000 FPS
Well brickie as long as you know that they are seating ok and no leaks then go for it. That is why I suggested the vacume test so you could check for a leaking injector before you put them in.
Old Feb 20, 2008 | 12:22 PM
bogginf350's Avatar
bogginf350
Just wipe them off with carb cleaner on a rag, never use a wire brush! The pintle is actually the needle inside the nozzle that regulates and controls fuel flow.
Old Feb 21, 2008 | 12:36 AM
brickie's Avatar
brickie
Thanks Josh.
FordOwnerJoey
Jan 21, 2014 09:21 PM
AndeyHall
Oct 19, 2010 06:02 PM
1bddelx
Mar 31, 2009 10:55 PM
mtcrss14
Nov 6, 2007 09:40 PM
mike L
Jun 17, 2006 06:47 AM
