Intake Mod V2.1
Old Mar 30, 2011 | 09:08 AM
  #91
vfelix702's Avatar
vfelix702
Well the benifit of making a cold air intake is that if your not happy with it u can go back to your old unmodifed unit
Old Mar 30, 2011 | 09:51 AM
  #92
Reddogdiesel's Avatar
Reddogdiesel
Already cut up the old one, just looking for a little more power and less smoke.
Old Mar 30, 2011 | 09:58 AM
  #93
1994F2507.3L's Avatar
1994F2507.3L
i imagine smoke has more to due with your fueling rather than your air intake.
Old Mar 30, 2011 | 10:29 AM
  #94
Reddogdiesel
As i mentioned i just got the truck. It has a new inj pump, new injectors, new vac pump. Should I maybe adjust the inj pump? It's got plenty of power but at 75 if i step on it to pass someone on I-10 it pours out black smoke. Is this just normal? This is my first diesel, I've always had big gas trucks.
Old Mar 30, 2011 | 10:33 AM
  #95
snaponprofile's Avatar
snaponprofile
Black smoke is partially burnt fuel, adjusting the fuel screw would solve that or perhaps your timing is off. Are you timing marks aligned, retarded or advanced? Do you know if they are new or the guy who sold it to you just said that?
Old Mar 30, 2011 | 11:13 AM
  #96
Reddogdiesel
They are new, i work for carquest and he bought the parts here. Not sure on the timing. How do i check that?
Old Mar 30, 2011 | 11:29 AM
  #97
snaponprofile
Where the IP bolts to there should be a timing mark engraved in the IP and the place where it bolts into. Lemme look for a pic, its gonna take way too long to explain.
Old Mar 30, 2011 | 11:33 AM
  #98
snaponprofile
Here ya go, just look right down on your IP and you should see these.
Old Mar 30, 2011 | 11:43 AM
  #99
Reddogdiesel
Ok thanks i will look
Old Mar 30, 2011 | 03:31 PM
  #100
wreckinball's Avatar
wreckinball
if it is a new pump and injectors etc etc, he may have adjusted the fuel screw or bought a turbo pump, which in either case, would be too much fuel for an NA.
Old Mar 30, 2011 | 05:56 PM
  #101
Reddogdiesel
Maybe I'm blowing this out of proportion. I filled it up today and figured out im getting close to 14mpg and part of that was with it idling for a couple hours with the ac running while I installed the stereo. Im guessing this is pretty good since my 98 chevy 3/4 ton with a 350 never went over 12mpg.
Old Mar 30, 2011 | 06:00 PM
  #102
wreckinball
mpg, and blowing black smoke at high rpm is different but the same. Sounds wierd but what i mean is that you can still get relatively good mpg's and melt your pistons. Idling is the best fuel mileage on earth. hard to factor that in.
BLADE35
Jan 8, 2015 04:50 PM
brooksbronco17
23
Nov 5, 2014 07:47 PM
tasboj
19
Jan 21, 2013 07:28 PM
ReBilld
51
Jul 14, 2012 06:39 PM
JOHN2001
Oct 23, 2011 05:11 AM
