Intake Mod V2.1
Old Jan 28, 2011 | 12:04 AM
  #76
cpetersen's Avatar
cpetersen
i just moved the screw down around the very bottom and it seems to stay we will see if it stays on my way to school in the mornin lol thanks man it looks preetty dang good ill get pics tomorow
Old Jan 28, 2011 | 12:12 AM
  #77
wreckinball's Avatar
wreckinball
i had to do that small mounting bracket to keep it still for good. Now with the CDR on the intake it is really looking good! hahaha. moved the CDR so it is one less thing i have to do when i go full bore on the install.
Old Jan 28, 2011 | 12:24 AM
  #78
cpetersen's Avatar
cpetersen
CDR? my filter doesnt really move so im thinkin im good for now
Old Jan 28, 2011 | 12:30 AM
  #79
wreckinball
crank case depression regulator, little tuna can on the back of the intake. has to move when turboing the truck. so i moved mine ahead of time so the install of the turbo itself goes faster. looks like this now
Old Jan 28, 2011 | 12:34 AM
  #80
cpetersen's Avatar
cpetersen
awe gotcha lol i dont know all the lingo but i know some of it lol im hopin this summer ill make enough that i can turbo mine
Old Jan 28, 2011 | 12:37 AM
  #81
wreckinball
sounds good man, im so friggin stoked to get it on!! haha, hmmmm.
Old Jan 28, 2011 | 03:18 AM
  #82
LCAM-01XA's Avatar
LCAM-01XA
Dude, this came out all sorts of wrong...
Old Jan 28, 2011 | 09:00 AM
  #83
wreckinball
maybe with the way you swing, but the way im doing it, its all good! hahaha
Old Mar 29, 2011 | 08:38 PM
  #84
Reddogdiesel's Avatar
Reddogdiesel
Intake ?
I tried to use a 5-4 rubber PVC adapter for an intake and it was entirely too big and there doesn't look like there is enough room to clamp it to the plenum anyways. Am i doing something wrong?
Old Mar 29, 2011 | 08:58 PM
  #85
vfelix702's Avatar
vfelix702
Well there gonna be play till you tighten the band... But your not trying to fit the "Hub" on the whole pletum just the 1/4 lip.... U might want to cut the ridge on the hub so its a flat surface solid for the clamp... I should have pics on the website if you need some let me know
Old Mar 29, 2011 | 11:03 PM
  #86
wreckinball
on the rubber reducer, there will be an indent where the band goes, cut(VERY NEATLY) all of the lip and indent off. Leaving it nice and flat, now put the band on and slide it on the intake, tighten it up and it will hold tight. You will need some kind of bracket depending on what you do with the filter and similar. Check my pics and you will see.
Old Mar 29, 2011 | 11:20 PM
  #87
frodfreak's Avatar
frodfreak
i plan on maken one, but maybe a bit diff. but u have made me think about doing cool mods wrec, so u cut the indent. off the reducer and moved the band up to the thicker part( check ) and made a mount to support the weight of the tubing( check ) did the reducer hold up to the heat??
Old Mar 29, 2011 | 11:26 PM
  #88
vfelix702's Avatar
vfelix702
My reducer is still holding up very well with no issues I installed it january of this year
Old Mar 29, 2011 | 11:28 PM
  #89
wreckinball
i ran it for two months and its been on my buddys truck for another two and its still soft. Its made to resist a lot of heat and my never sees over 110. The intake neck stays cold. Like the turbo intake housing as i have now never sees over 130 and its metal. only when i sit in traffic does it get that hot, if im running down the road, its cold when i touch it. It stays a lot colder in there when you have it setup like mine.
Old Mar 30, 2011 | 09:04 AM
  #90
Reddogdiesel
Ok thanks, i guess ill try again this weekend. Just got the truck and so far so good. Tried removing the muffler, but made the truck run horrible. Does the intake mod work much better than cutting up the factory setup?
