throwing p0237 code
Old Jan 9, 2011 | 01:31 PM
04WVPSD's Avatar
04WVPSD
Cool throwing p0237 code
Just finished egr delete and new oil cooler. Nipple on map sensor was broken. Glued together until new one comes in. Will this cause the p0237 code. Also still puking out degas bottle. Looks like new HG's are next.
Old Jan 9, 2011 | 01:33 PM
npccpartsman's Avatar
npccpartsman
Yes, it will definitely cause the p0237 code. Do you have the degas bottle filled correctly (1/2" below the minimum line?)
Old Jan 9, 2011 | 01:39 PM
04WVPSD's Avatar
04WVPSD
yes. its actually slightly below the min line. Does fine until truck is under load, pulling or not. Seems like when I go up a long hill it pukes pretty badly. Also done a vc-9 flush before cooler change so everything should be clean.
John Gilliam
Jun 23, 2017 06:00 PM
rickdavis81
May 12, 2016 04:34 PM
Mrplow91
34
Jan 21, 2016 06:22 PM
keith kunkle
Large Truck
Nov 18, 2015 03:55 PM
Matt306
Sep 5, 2015 08:50 PM
