Truck help
Old Jun 23, 2017 | 03:43 PM
John Gilliam's Avatar
John Gilliam
Truck help
Hi everyone, I have a 1999 Ford F-350. I have six codes from my truck and need help. The codes are P0237 P1119 P1690 P0500 P0603 P0344. My truck runs, but likes to stall out on me for no reasons at times. The other problem I am having is between 1,800-2,500 rpms, she shutters or pops. Any help is appreciated!
Old Jun 23, 2017 | 03:54 PM
Kamstutz's Avatar
Kamstutz
P0237 Turbo boost sensor A circuit low input, Circuit open - short to ground, MAP sensor
P1119 Manifold air temp sensor out of range high - Open/short to PWR circuit, MAT sensor
P1690 Waste gate failure, WGC circuit or solenoid - PCM P0500 Exhaust pressure control valve high input Plugged sensor line, stuck butterfly, restricted exhaust
P0603 Internal control module KAM error - Open PCM pin, disconnect B+, faulty PCM
P0344 Camshaft position sensor ckt. intermittent - Harness routing, charging ckt., sensor, int. ckt., improper gap
Sounds like you may have an electrical problem.
Old Jun 23, 2017 | 04:01 PM
John Gilliam
I figured I had an electrical problem, so I cleaned the terminals at the battery and cleaned the grounds on the block. The pcm was replaced about a year ago. I'm just finishing this truck up and was hoping to finally get it on the road.
Old Jun 23, 2017 | 04:13 PM
Kamstutz's Avatar
Kamstutz
Look at the engine wiring harness on the drivers side valve cover. There was an chaffing issue.
Old Jun 23, 2017 | 04:47 PM
John Gilliam
There's not really any chafing. I checked the connector on the driver side valve cover. It was a little loose so I tightened down the 10mm bolt. Didn't really help out that much. Any other suggestions?
Old Jun 23, 2017 | 04:53 PM
AllaboutMPG's Avatar
AllaboutMPG
Do you have a chip. check connection.
check connection at PCM
Old Jun 23, 2017 | 05:49 PM
John Gilliam
No chip. Completely stock. I'll check connection at the pcm.
Old Jun 23, 2017 | 06:00 PM
z31freakify's Avatar
z31freakify
Check your UVCH and pig tails, classic symptoms burnt pins.
joegebff
17
May 2, 2013 05:50 AM
greystreak92
1978 - 1996 Big Bronco
15
Apr 16, 2013 09:41 PM
ken324
May 7, 2011 06:52 PM
sneak
Jan 24, 2006 09:09 PM
cmrclgc
May 6, 2004 10:17 AM
