1978 - 1996 Big Bronco
Front Bench Seat
Old Jan 5, 2011 | 09:07 PM
Mauch1's Avatar
Mauch1
Front Bench Seat
I just bought a 1979 Bronco and the previous owner put a set of racing seats in the front (mounted poorly) and i want to get my hands on a OE front bench seat but im having a hard time finding one. Does anyone know where i might find an inexpensive bench seat for this year of bronco? thanks!
Old Jan 29, 2011 | 09:21 PM
Joseph69's Avatar
Joseph69
Any 73 to 79 ford truck should fit. I dont think they ever put a bench in the bronco because you couldnt get into the back seat with it, but the floorboard is the same as the trucks, just pull the bench out of a truck
Old Jan 29, 2011 | 11:41 PM
StuntmanFyke's Avatar
StuntmanFyke
newer seats will work as well, just make sure to use the right floor mounts. but yeah, it does make it more difficult to get in the back
Old Jan 29, 2011 | 11:46 PM
bertha66's Avatar
bertha66
Ford did put bench seats in Broncos, I have seen a few of them. There was one in the U pull it yard in Redmond Or about a month back. Was over there last week end and it was gone. But look around in your local wrecking yeards, you may find one.
Old Jan 30, 2011 | 12:04 AM
StuntmanFyke
ive seen a couple, an i know atleast 1 of em was owner installed. I prefer the stock buckets and center console myself.
Old Jan 30, 2011 | 05:03 AM
jacfordf-250's Avatar
jacfordf-250
get seat mounts 73-79 seat. And all bench seats will fit in 73-96 with the right floor mounts
Old Jan 30, 2011 | 02:53 PM
greystreak92's Avatar
greystreak92
Base line Broncos came with the bench seat. Not sure about the older models but the 89+ model years had the tapped holes in the floor for both the buckets and the bench seat mounts. The holes that weren't used, were plugged with plastic caps.
Old Feb 1, 2011 | 04:31 AM
rodeobroncrider's Avatar
rodeobroncrider
i got a bench seat in my 83 bronco and its the original but its a split back seat and a pain in may rear seat........
Old Feb 1, 2011 | 09:55 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
My '86 came with a bench, I swapped a split back out of a '91-ish extended cab pickup onto the stock brackets. Sits nice.
Old Feb 1, 2011 | 11:58 AM
AbandonedBronco's Avatar
AbandonedBronco
My '84 has a bench. Waaay more comfortable than my 81's bucket seats.
It also isn't that much more difficult to get in the back.
Old Feb 9, 2011 | 03:51 AM
hydrosmith's Avatar
hydrosmith
I had an '84 XLT that had a split bench. I like the buckets and console but the old lady can't sit close!
Old Jul 10, 2011 | 10:43 AM
Mauch1's Avatar
Mauch1
Sorry i didnt come back and post to this sooner but i solved my bench seat problem by going to a you pull it place and i took a split-back bench seat out of a 70-something super cab pick up. Just drilled new holes and installed. Sits nice and i couldnt be happier
DieselCamper
Aug 8, 2016 05:41 PM
mateosis650
Jul 7, 2014 01:53 PM
hivoltj
May 13, 2014 12:20 PM
Funluvncwgirl
13
Jul 21, 2011 09:22 PM
thatsrealnice
Jun 10, 2010 01:29 PM
