1978 - 1996 Big Bronco
Seat swap = buckets for split bench?
Old May 8, 2014 | 10:42 AM
hivoltj's Avatar
hivoltj
The buckets in my '95 XLT are fair with the good canvas seat cover on them, but I hate the center console and would like a seat for one more. I borrowed my dad's '79 Bronco for a while when mine was down and really liked having the split bench in the front. I'd like to either swap the buckets for a split bench or get a center jump seat out of something else and bolt it in, ideas?
I'd assume a front bench from another bronco or a supercab pickup is what I would need? What have you all done?
Old May 8, 2014 | 05:48 PM
Kemicalburns's Avatar
Kemicalburns
i went the center jump seat route. it was bolt in. any for truck would have it typically. grab the seat belts if you can
Old May 9, 2014 | 10:35 AM
hivoltj's Avatar
hivoltj
Any pics? Did you just drill and bolt it to the floor pan? I swapped a dodge center seat in to my Lightning, but it had a seat pan that the buckets bolted to, I just drilled and mounted to that.
Old May 9, 2014 | 01:05 PM
Kemicalburns
no need to drill, the center jump seat bracket utilizes the center bolt locations of the bucket seats. not the best picture but you get the idea.
Old May 10, 2014 | 11:20 AM
Fordman96's Avatar
Fordman96
I like your interior Kemical, same color as mine, but it seems nicer in yours.
Old May 12, 2014 | 09:27 AM
Kemicalburns
pics are deceiving. The interior is coming out here in another month due to mold. My top is leaking and with the carpet and such its just created this breading ground for mold. The seats will get shampooed and dried out in the sun, carpet will be pulled an interior rino lined.
I will say these stang seats are comfy though.
Old May 12, 2014 | 12:47 PM
hivoltj's Avatar
hivoltj
I spied a gray cloth center jump seat in an '06 F-150 at the yard this weekend, looked like it would fit nicely and had seat belts attached as well as cup-holders. Didn't have any torx sockets with me or I would have snagged it.
Old May 12, 2014 | 02:47 PM
Kemicalburns
unsure if that year center jump would fit. I suspect it would need to be 80-97 F150-f350
Old May 12, 2014 | 02:49 PM
hivoltj's Avatar
hivoltj
Well anything will fit, just depends how hard you want to work! I measured the width and it will fit between the seats. Of course holes would have to be drilled in the floor pan with some reinforcement added to the bottom, only issue I could see is if the tranny or t-case is in the way of getting to the bottom side.
Even if so a piece of strap could be welded to the top of the floor.
Old May 13, 2014 | 10:28 AM
Kemicalburns
might as well grab both driver and passenger seats so they match if your going thru that much work just for a center jump seat.
the one from our year trucks is direct bolt in no fab necessary. Take pics as I am sure it would look sweet with the 06' setup
Old May 13, 2014 | 12:20 PM
hivoltj's Avatar
hivoltj
Well, I worry about the flip forward feature on some newer seats, I don't think they would flip and slide like our bronco seats do. Plus the driver's seat had a cig burn so I didn't really want it.
hail destroyer
Nov 23, 2016 11:21 AM
RANGER589
15
Jun 29, 2011 07:50 AM
Equestriana
21
Apr 13, 2008 11:07 AM
Sycostang67
Mar 8, 2007 01:14 AM
Fullcrew7.3
Appearance & Dress-Up
Feb 18, 2005 04:45 PM
