1978 - 1996 Big Bronco
Jump Seat needed
Old Jul 20, 2011 | 04:55 PM
Funluvncwgirl's Avatar
Funluvncwgirl
Jump Seat needed
Just purchased a 92 bronco -- all set up for wheeling-- has bucket seats, but no jump seat. I have seen a bench seat will be a pain in the rear... so am wanting to put a jump seat in the middle of the front. Any ideas as to what years/ other model will fit?
Old Jul 20, 2011 | 09:27 PM
Edgethis's Avatar
Edgethis
You'd could fit a bench seat up front, not sure if thats what you meant. But I don't think you could "legally" have a jump seat in the middle as it'd prolly have no belt provisions.
Old Jul 20, 2011 | 10:12 PM
jigs-n-fixtures's Avatar
jigs-n-fixtures
One from a F-150 will fit. If you can find one.
And, there are after market ones.
You will need to add a center seat belt. But, you could doble mount to the factory mounts.
From my lessones learned files, a down side you might not have thought of: The access to the back will severely limited.
Old Jul 21, 2011 | 09:50 AM
Kemicalburns's Avatar
Kemicalburns
you can get a center jump seat from any F150,F250,F350 that came with the 40,20,40 split.
Just pull out your center console and remove both front seats. be sure to grab the seat belts from the same rig or piece some together from a bench seat rig. I have this exact setup in my bronco. makes it real nice
Old Jul 21, 2011 | 10:12 AM
deadeyedevon's Avatar
deadeyedevon
second above, a toolbox and a junkyard and your in business. i was thinking about swapping out my factory seats for something cooler, i was just going to pull the center console, rotate it 180 degrees and mount it closer to the dash, that way there would be acess thu the middle to the back seat. the only people that sit in my back seat are usually my kids so it should be plenty for them
Old Jul 21, 2011 | 12:26 PM
Kemicalburns
oh i forgot to mention that you will need to pull your arm rests off your current bronco bucket seats. so if the truck you pull the jump seat from has both driver/passenger seats in great condition and you can get them for a good price you might grab them also and just swap the whole set into your bronco. I eventually installed some Mustang gt seats that i am very happy with although they are more of a black/grey vs the blue interior i have.
Old Jul 21, 2011 | 12:36 PM
deadeyedevon
did the mustang seats fit in good with the bronco brackets or did you use the mustang brackets?
Old Jul 21, 2011 | 12:46 PM
khadma's Avatar
khadma
Carpenter Local 745
Did you guys see my build thread?
F350 seat installed up front.
I am using my iPad and can't copy and paste yet.
Old Jul 21, 2011 | 12:47 PM
deadeyedevon
checkin it out now,
Old Jul 21, 2011 | 12:53 PM
khadma's Avatar
khadma
Carpenter Local 745
here is the link
https://www.ford-trucks.com/forums/9...l#post10528710
Old Jul 21, 2011 | 01:15 PM
AbandonedBronco's Avatar
AbandonedBronco
What's a pain about a bench seat? My '84 has a bench seat and it isn't much more difficult than my bucket seats to get in the back. A little, but not a showstopper.
Old Jul 21, 2011 | 01:20 PM
deadeyedevon
so you just installed the center jump seat right? or did you swap out all the front seats? couldnt really tell in the pics
Old Jul 21, 2011 | 04:46 PM
khadma's Avatar
khadma
Carpenter Local 745
I only installed the jumper seat, I got it off of ebay.
It is hard to locate used parts here, the recycle yards are small and they
Move their inventory fast - think available land space - anyway, it was worth the cost of the item and related shipping.
I was planning to use a bench seat from a same era single cab F150, but those seats don't recline, but the will offer enough space to enter the rear seat.
I chose the jump seat as a personal choice.
The jumper seat I bought did come with a seat belt. I was able to use the stock belt mounting points.
I Also used grade 8 bolts for the seat installation.
Although the seat materials don't match, we are going to install Wet Okole covers after I remove the carpet and install new vinyl flooring.
Old Jul 21, 2011 | 09:22 PM
deadeyedevon
sounds sweet,..something for me to put on my junkyard search list
Canvas Man
WTB - Parts & other
May 20, 2016 07:33 PM
dongeovani11
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jun 29, 2014 11:34 PM
jgavac
Mar 1, 2013 04:18 PM
Cowboyswebb82
Nov 7, 2010 10:13 PM
