Agreed 69cj. Once I saw that slugde, along with the reddish sludge that has settled in the bottom of the degas bottle, there's no doubt that a good VC-9 douching is in order
I have 2 quarts of VC-9, 3 gallons of Ford Gold, and many gallons of distilled water on hand in the garage, as soon as I get back in town, a coolant flush is top on my 'Honey-Do' list.
There is some debate on whether VC-9 contributes to oil cooler clogging. My oil cooler was replaced this past May, and I sure don't want to pay for that again!!
Thoughts?
Since you mentioned the word sludge I think I would flush with a gal. of simple green before the vc-9. That is a procedure that cheezit, a 6.0 tech, uses. It would clear the sludge and allow the vc-9 to do it job on the metal parts.
I know this was a couple months old, but thanks to the "search" feature i found this thread and used the guide to replace a suspected bad thermostat today. It went pretty smoothly however the last two nuts holding the studs decided they were going to take the studs with them, so i replaced the t-stat and had to take the bolts completely out
Just finished my VC-9/Simple green flush this past weekend. Boy did it take a lot of DI water to finish flushing the system. Fortunately i work for a laboratory and have access to unlimited DI water from our treatment system. It Still took 7 Flush/drain sequences to remove all the foaming/odor of the simple green. That was draining at the petcock/lower radiator hose/RH block plug. I wish i had read this post for the info on the bolt/stud by the fuel line. What a pain it the &*^. A few of my problems that i had to figure out.
1) the Thermostat really is pretty easy to remove and should be done to speed the flushing process. It took me all afternoon to flush 7 times. Figuring 30 minutes per flush/fill it was all afternoon. I was distracted by March Madness at times so it took a little longer. Also at about 4 gallons added/removed per flush cycle i needed 35 gallons of DI Water (I had to make a second trip to the lab to get more).
By my calculation at 7 flush cycles there is approximatly 1.2 oz of simple green and 2.5 oz of VC-9 Still in the system by dilution that should have no impact on the cooling system.
2) Get ride of the squeeze hose clamp. I put everything back together with that clamp and had a nice leak. So I had to take everything apart and put on a screw type hose clamp.
My Coolant temps before were running 178-185 with a less than 15 differentianl on oil temps. So I figured I needed to replace the thermostat. Coolant has been changed prior a couple of times. Afterwards, coolant is running 188-190 with a less than 3 differential. I am happy i did this.
